Go Fast Bit: Stealth/Deceptor FX Blow-Off Valve: REVIEW
Old Sep 3, 2009 | 02:16 PM
Clipse3GT's Avatar
More actual pictures to come tomorrow:
After much trial and error with the FORGE RS BOV, I decided to make a switch back to stock. However, it my stock valve having issues with my tune and holding 26psi. I decided that I need to go to the market and find a suitable for the EVO X. My search started with looking at the WORK EVO X BOV, which was like the stock one except with upgraded internals and spring. After contacting WORKS, tell said that maybe a good choice would be the GFB: Stealth FX BOV. After some research and searching I decided to make the switch. My other choice was the Synapse BOV.
I have to say having it on for a week now that I am very impressed with the BOV from GFB. The quality of the workmanship and CNC work is top notch. It was well packaged and the instructions were clear and to the point.
So far I have tried most of the modes, which include full recirculation, full VTA, and the many settings of recirc and vent to atmosphere.
I come to small conclusion that right now for daily driving, I have the valve setup for 70% recirc and 30% VTA. Sounds great and works well, no ill effects for gas mileage, I will check the wideband after I install it this weekend.
My setting for the tension is 2 full turns + from all the way negative. It holds the piston closed a bit longer when in vacuum and highway cruising however it does produce a tad bit of piston flutter. I will try uping to three full turns and see how the car responds.
So far there is no CEL for any reason, no p1241 that I used to get with the FORGE RS.
After speaking with Brett @ GFB. I have some tuning tips for anyone looking for a GFB BOV or has one already.
How To: Check if GFB BOV has a leak
Originally Posted by Brett@GFB
I’m assuming from your question that you’re trying to determine if your valve is “leaking boost”, would that be correct? The reason I ask what may seem an obvious question is that the term “leak” should be used in context, i.e. in conjunction with a magnitude. For example, your test of applying boost pressure to the nipple and detecting a leak out of the outlet ports does show a leak, but I guess the real question is “does this leak affect the BOV’s performance and its ability to hold boost pressure?
Much like the pistons in an engine, there will always be a small amount of “leak down” past the piston from the top chamber to the outlet ports – this is unavoidable on any valve that vents to atmosphere because a prerequisite of venting to atmosphere without idling problems is almost zero friction of the piston movement. It would be possible to seal the piston 100% using an o-ring, but unfortunately o-rings (no matter how loosely compressed) will always cause friction, which will severely compromise a valve’s performance when venting to atmosphere, leading to stalling and backfiring issues.
I can say with 100% certainty that the leak you describe won’t cause the valve to open under boost, cause the boost pressure to drop, or change the air/fuel mixture. I can say this with such certainty because of the following. The valve you have will remain closed as long as the pressure at the top is equal to or no more than about 6psi less than the boost pressure in the intercooler pipes – this means the leak would need to be large enough to cause the pressure in the top of the valve to drop more than 6psi below the intercooler pressure in order for the valve to open under boost. Unless this happens, the valve simply will not open.
A leak large enough to cause a 6psi pressure loss in the top of the valve would also render the valve inoperable – i.e. when you lift the throttle there would not be enough vacuum to open it and it would not vent. In fact it takes less of a leak to prevent the valve from venting when you lift the throttle than it does to allow if to lift under boost, so therefore if the valve blows off normally when you lift the throttle, it can be said with confidence that it is not opening under boost.
Now, the leak itself – does this affect boost pressure? If the valve vents normally as per the above, no. A leak that causes a loss of boost pressure, or that can even be measured as a percentage of the air that the engine consumes needs to be pretty big, like something about the size of an 8mm hole or so. As a comparison, a boost control solenoid or bleed valve typically leaks about 10 times more than the amount of air that leaks down past the piston on the BOV. Of course, without being able to see the valve I cannot say for sure if the amount of air you have leaking out is within what I would say is a normal range, but I can say for sure that the above argument about its operation is still valid – i.e. the valve will continue to work properly even if the leak were larger than normal.
In a nutshell, to confirm the BOVs operation you can do the following:
* Check if the valve vents normally when you lift the throttle, if yes, then even if it does show an air leak by bench testing or smoke testing, it will not cause a boost pressure drop or affect the car’s performance in any way.
* To further confirm, you can measure the boost pressure at the manifold, and then measure it in the BOV vacuum hose. If there is a difference of less than 6psi, it can be safely assumed the valve is not opening under boost.
I hope this information helps, but of course as I have made a few assumptions along the way please feel free to comment if they are incorrect. If the leak is exceedingly large but the valve still operates normally, it is possible some damage has occurred to the piston that can be easily fixed. A very non-scientific method to use to determine if the leak is within a normal range is to suck on the vacuum nipple. If you can pull a vacuum and hold it for a few seconds, then it will undoubtedly fall within the normal range. If you cannot hold a vacuum at all (i.e. can draw breath through it), then I would say it probably should be looked at for peace of mind.
Let me know how you go with the tests, or if you have any further information about relevant symptoms please let me know.
How To: Tune GFB BOV
he good thing about the EVO X is that it runs a hot wire type MAF sensor which is less sensitive to BOVs than the Karman Vortex type found on the earlier EVOs, so you have more flexibility on the BOV settings.
Our testing has shown that best throttle response is achieved with firmer spring settings, which typically only allow the valve to start venting when the car is being driven in a “spirited” fashion. This is because a firmer setting will hold slightly more pressure in the intercooler and pipes during a gearshift, and hence shorten the time it takes to get back to full boost when you re-open the throttle (not really an issue if you have the SST model though since you don’t lift the throttle to shift). This will however increase the amount of flutter you get when rolling off the throttle slowly, or lifting off before the turbo has fully spooled, but as long as that noise doesn’t bother you, there is no harm in setting it up this way and there is a small improvement to be had.
Best regards,
Brett Turner B.Eng. (Mech)
Design Engineer
Go Fast Bits
Phone: +612 9534 0099
Skype: brettturner77
brett@gofastbits.com.au
www.gofastbits.com.au
Old Sep 3, 2009 | 02:38 PM
Noize's Avatar
EvoM Administrator
Where is it available to purchase?
Old Sep 3, 2009 | 03:00 PM
gsrtroy's Avatar
heres there website, it looks pretty expensive
http://www.gofastbits.com.au/index.p...id=85&Itemid=4
Old Sep 4, 2009 | 02:17 AM
tonyboy's Avatar
^^interesting...but it is quite expensive...
Old Sep 4, 2009 | 11:07 AM
4myX's Avatar
Im glad its working great for you! this was the worst bov I tried. I tried every adjustment in the book and no luck. Some of the reasons could be because I was running more boost and had a different turbo too.
Old Sep 21, 2009 | 04:45 PM
GFB Pete's Avatar
Hi everyone,
Clipse3GT, glad to hear the Stealth FX is working well for you.
I should point out that the prices on the GFB website are in Australian dollars, which might be the reason it looks pretty expensive. I'd suggest contacting WORKS or Global Performance Parts for accurate US pricing.
Aside from making noise and holding boost, there is actually an additional benefit to the Stealth FX in the form of throttle response improvement - here's an article on the topic that may be of interest:
http://racedotcom.com/showthread.php?t=27445
4myX, I'm interested to hear what issues you had with your Stealth FX, can you fill me in?
Best regards,
GFB Pete
www.gfb.com.au
Old Sep 25, 2009 | 09:44 AM
troy@WORKS's Avatar
Here is the link to the GFB Stealth FX Dual Vent Valve http://www.worksevo.com/store/produc...products_id=34 WORKS and Go Fast Bits have had a long relationship and we recommend the Stealth FX to the EVO Enthusiast looking for the appearance, durability and sound of a quality CBV, but not willing to compromise overall drivability. Let us know if you guys have any questions about this great product.
Old Sep 30, 2009 | 08:33 AM
ChrisCarey's Avatar
It just so happens that GFB is discontinuing the color variations of this valve (they will only offer black in the future) which is allowing us to offer some pretty crazy pricing on one of the best valves on the market Click here for more information, we only have a few of each color left so act fast!
Old Sep 30, 2009 | 08:48 AM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
this is THE only valve i would use on a X if shying away from stock for any number of reasons...get them guys
Old Sep 30, 2009 | 08:50 AM
solarevo's Avatar
i have a forge rs and have not had a single issue, plus i dont have the ricer pssssshh sound
Old Sep 30, 2009 | 08:53 AM
Clipse3GT's Avatar
You must be the chosen one, since everyone else on here has issues with the FORGE RS.
Old Sep 30, 2009 | 09:20 AM
solarevo's Avatar
LOL i guess i got lucky with this one, we will see if i have any issues with it after the tune in december, "cross my fingers"
Old Oct 1, 2009 | 02:40 AM
didi1000000's Avatar
I bought this GFB one last week, works great for me except a little bit low rpm fluttering when car is cold, and it gets much better after the car warms up. I would say the less mods you have done to the car the less issue you will have with an aftermarket bov.
Old Oct 1, 2009 | 05:08 PM
itoen's Avatar
You are the man for sharing all this info
Old Oct 12, 2009 | 07:05 PM
raytrix's Avatar
this guy does a great feature on the BOV and it's features.
http://www.youtube.com/watch?v=kRf94Q2zM2M
