Go Fast Bit: Stealth/Deceptor FX Blow-Off Valve: REVIEW
Old Oct 19, 2009 | 03:32 PM
raytrix's Avatar
I just got this BOV in today thanks to MAPerformance. This BOV is nice. I was able to hold peak boost for 1.5-2 sec. No turbo surge or fluttering. I'm at 3 full turns from full negative. 30% VTA 70% recirculate. It doesn't psssh under low load under 3k throttle Only when you half throttle it then it will open up the piston pass the VTA port to psssshh.
Old Oct 20, 2009 | 12:23 PM
didi1000000's Avatar
Hi there, are you having the factory intake or the aftermarket one? Will you have any idle problem if you set the spring pre-load to its softest end, or you just set it the way to avoid surge?Thanks.
Old Oct 20, 2009 | 01:04 PM
ChrisCarey's Avatar
Glad to hear you like it sir! We only have two left in blue if anyone else wants to take advantage of this special pricing!
Old Dec 16, 2009 | 02:48 PM
livnpaintball2's Avatar
these things KA. I put one on today 70VTA with 4+ turns on the spring. Works great
korizmo
Apr 27, 2012 11:41 AM
SILVER SURFER
241
May 5, 2011 07:25 PM
Clipse3GT
40
Jan 13, 2011 07:31 PM
mrfred
11
Jan 4, 2010 08:13 AM
xtnct
12
Jun 14, 2007 08:21 PM
