AFR idle/driving/accel? I need some Opinions on this
Ok so I just got some videos of Idle, driving normally , & a quick pull in 3rd. I've changed everything I can think of its not a leak so I am assuming I should hand this over to a tuner???
The car seems to run fine but I have noticed a reduction in performance & gas mileage as well.
IDLE:
Driving:
https://www.youtube.com/watch?v=JQOX8i9zV8I
Acceleration 3rd gear:
https://www.youtube.com/watch?v=RfUx-7HjYE8
IDLE:
Driving:
I've only adjusted for boost cut & simple things, not fuel or timing has been changed.
The Video didn't catch the jump to 17 @ idle It only happens for a split second or 2. or when it drops to 11-12 the car sounds like its bogging down bad.
What do you suggest the fuel trims be at? & which tables do I need to post?
I couldn't tell by the vids what your main concerns are.
Idle seemed pretty normal by its consistency, I'm guessing its not 100% accurate... driving off throttle seems like it doesn't go into fuel cut quick enough but its hard to tell without some logs
Yeah, I'm trying to get some logs my laptop crashed so I'm waiting on the new HD in the mail. No exhaust components where changed since the WB was installed only difference was the EGR delete was the last thing I did. I've trippled checked it & It's 100% sealed. I rechecked the calibration because I thought it might have been off, but even after resetting it. Same outcome , The car feels sluggish, I'm trying to figure if i need to get this tuned or if I could just change a few things myself to get the a/f up a bit leaner.
The thing is I've noticed it go from a healthy 14.7 idle, no bogging down. a nice pull throughout the power-band.
to the car feeling like its running in limp mode, but of course its not... I'll check the down-pipe that's the only part that the wide-band is on so it would be the donut gasket on the o2housing if there is a leak....
Cars getting 196mpg on a full tank... which my last evo with 1000cc got almost 240 on a full tank... It's just wasting fuel badly & causing very noticeable reduced performance
Boost leak checked up to 30psi no leaks, & i just got under the car to check if one of the o2 sensor plugs came out but everything is all tight.
I'm assuming the egr removal needed to be compensated in the tuning...?
Yes stock injectors, I'm trying to get my friend that has Evoscan on his gsx to swing by so I can get some logs going on this thing. I recalibrated the WB again this morning & its still the same outcome.
