Stock boost solenoid lines
Old Jan 31, 2004 | 01:40 AM
NRG's Avatar
NRG
I was wondering if you guys know if there is a pill in the lines that go from the turbo to the control valve? If so, would replacing the line help increase boost if I was to put in a boost controller.....
Old Jan 31, 2004 | 07:36 AM
EvolvedDSM's Avatar
Search!
https://www.evolutionm.net/forums/sh...threadid=32458
Old Jan 31, 2004 | 08:53 AM
NRG's Avatar
NRG
Searching does help huh? But my real question is, should I take off the pill if I use a EBC.....
I heard WORKS reflash P2, they take that off so the boost doesn't taper at or near redline.....
Old Jan 31, 2004 | 08:57 AM
EvolvedDSM's Avatar
If that's your question, then why didn't you ask it? An EBC completely bypasses the BCS and there's no reason at all to use the stock tubing.
Old Jan 31, 2004 | 09:15 AM
NRG's Avatar
NRG
So are you saying with the EBC, I should use the tubing that came from the EBC? Meaning I should connect the tubes from the EBC to the wastegate actuator and one to the turbo inlet and cap the rest......?
Old Jan 31, 2004 | 10:38 AM
EvolvedDSM's Avatar
I'm saying follow the instructions of the EBC. You are making this way too complicated.
