My DOOR mystery with pics?
Old Jan 27, 2004 | 03:13 PM
batty's Avatar
My DOOR GA begins
Ok i posted a cou
Old Jan 27, 2004 | 03:31 PM
batty's Avatar
wondering if anyone elses door looks like this. Its strange cause the door is perfectly aligned to the rear door. I checked out the door jam etc..... couldnt find anything.
Old Jan 27, 2004 | 03:38 PM
darknightohio's Avatar
Take it back to the dealer and demand a new door!
Old Jan 27, 2004 | 03:42 PM
StinkyTofu's Avatar
Yeah right, the stealership will void your "door" warranty because they spied on you and saw you gun it on the freeway =P
Old Jan 27, 2004 | 03:49 PM
Secret Chimp's Avatar
Is it the gap between the 2 panels you are worried about? Or is it the dark open space behind the gap that is troubling you?
SC~
Old Jan 27, 2004 | 03:50 PM
batty's Avatar
i can see it com
Old Jan 27, 2004 | 03:52 PM
batty's Avatar
Its the gap and the fact the door suddenly became recessed. Meaning if u run ur finger down that body line it drops off like half an inch to the door. THe passenger side sits flush with the quarter panel.
Old Jan 27, 2004 | 05:12 PM
exhaust_note's Avatar
nice pink evo...lol... are the hinges tight???
Old Jan 27, 2004 | 07:06 PM
batty's Avatar
hinges are tight. YUp pink it is. Every picture i have taken at night, up close makes the car look pink. Every Red EVo will always look pink when taken up close with a flash.
Old Jan 27, 2004 | 07:08 PM
Quickshift's Avatar
Can you see behind the hinges and see any scrap marks from where it was previously set? That is just weird.....
Old Jan 27, 2004 | 07:10 PM
batty's Avatar
see always looks pink with a flash
Old Jan 27, 2004 | 07:15 PM
batty's Avatar
THere are no scrap marks f
Old Jan 27, 2004 | 07:25 PM
new 2 turbos's Avatar
are you sure that it is the door and not the fender that came loose? try looking at the fender bolts too. just a thought. night have to pull the fender liner out to get to the inside bolts, not sure on that though. haven't "scrapped the caddy," yet. if you know what i mean!
good luck with that.
Old Jan 28, 2004 | 02:08 AM
limey's Avatar
there could be a problem with the "check strap" the part in the door that keeps it from opening fully
Old Jan 28, 2004 | 08:46 AM
If the door closes normally, and the door rear edge is still flush with the b pillar, I would seriously suspect the front 1/4 panel.
Take a look at the shut line between the hood and the top edge of the front 1/4 panel. Is it uniform in size? Is the gap less or more than the shut line on the passenger side?
SC~
