motor mounts DD
Old Aug 19, 2012 | 05:05 AM
211Ratsbud's Avatar
I bought a full torque solution kit from stm.. A month ago I'm so hesitant to put them in! Haha
Old Aug 19, 2012 | 12:45 PM
selp's Avatar
From what I hear the front engine mount is the best option for a daily driver. considering that a daily driver falls in the category of comfortable smooth ride.
Old Aug 20, 2012 | 09:23 AM
elim0's Avatar
i will just get the front torque solutions one on and see how it goes. if for some reason it is too soft for me and i am willing to go harder, which side mount should i go next (the tranny side or the cam gear) ?? or should i do both ? ...... (dw i know not to do the rear one lol)
Old Aug 22, 2012 | 01:04 AM
elim0's Avatar
does anyone know how avid racing mounts are .. apparently they have 62a rating ones which would be most ideal for street use ?ive heard as just doing the front puts more wear on the other mounts ?
Old Aug 22, 2012 | 05:15 PM
TurboTal's Avatar
I have polyurethane mounts in my DD, had them for years, but boy do I regret them for 90% of the time in the car.
Old Aug 22, 2012 | 05:56 PM
AreSTG's Avatar
Originally Posted by Rmeister007
Unless it gets your gf horny....then do whatever u want. Lol!
balance shaft delete helps with this one too
Old Aug 22, 2012 | 07:24 PM
4RETECH's Avatar
I have the OEM mounts in my car.
Old Aug 22, 2012 | 09:01 PM
elim0's Avatar
how bad is the vibration and what durometer are your mounts? do you have the rear one too? as ive heard thats the worst one for vibration.. but my mech and others have mentioned getting one mount will wear the other oem ones more?
Old Aug 24, 2012 | 01:20 AM
Rmeister007's Avatar
I just did the Blox front MM. Very minimal vibration. Hardly even noticed it. In fact I can't believe people complained about the 90A durometer vibration. Wow!!!
I'm now gonna get the sides.
Old Aug 26, 2012 | 08:59 AM
elim0's Avatar
i spoke to a mate who had run 62a mounts (3) in his honda and said it was horrible for DD, said it felt like bolts were gonna shake loose and his car fall apart. i also spoke to my mech who suggested motor mounts are no good for DD and suggested i get a engine damper but a good one (he suggested HPI)...
Im tossing up between the HPI torque damper and/or Torque Solutions front motor mount now..i am worried the mount will ruin my day lol, although some people say after a week or two it will settle in ?
Old Aug 26, 2012 | 09:46 AM
1hotevo9's Avatar
+ 1 for the Blox front mount
I replaced the front mount last week and I like it alot.
Old Aug 26, 2012 | 10:27 PM
Normally, I wouldn't care enough to post again on a forum after I've given my final verdict, but let me tell you, the Blox front MM is AWESOME! Shifting feel has GREATLY improved tremendously while moving. The vibration is almost non-existent. On a scale of 0-10 (10 shaking all hell), I'd say the vibration is like a 1 or a 2. I'd def recommend this mod without a doubt! Now I'm gonna do the tranny and camgear mounts and avoid the rear at all costs....
Old Sep 3, 2012 | 09:11 PM
hermin0000's Avatar
After doing a blox front MM (90a) if you choose to do the sides, do you have to install the same rating(90a) on the sides? If so is there a company that does that? Does blox do it?
Old Sep 3, 2012 | 09:22 PM
blknblubkrdude's Avatar
I was having problems with chatter on clutch engagement from a stop, I replaced the front MM with a Minerva Motorwerks, and my problems dissapeared completely. Suprisingly, my OEM mount was not torn or loose - just plain 'ol worn out. There is no extra vibration with the mount, under any condition.
Best bang for the buck mount available!
Old Sep 3, 2012 | 11:22 PM
intj123's Avatar
Actually I have the torque solution rear mount only, and stock rest. It is 75A durometer and it almost feels stock. I also have an engine torque damper too. The only time I get vibrations is when I have the A/C on at idle and if I set the torque damper too stiff. Otherwise it is much smoother than I expected seeing that the bottom end is solid. It also allow much more clearance for removal of the transmission mount bracket and allows a torque wrench to be fitted on. Not a huge difference though, stock ones are not bad if you just have an engine torque damper.
