Autopower Roll bar question
Old Sep 5, 2012 | 08:39 AM
Pssst's Avatar
Hey I picked up a auto power roll bar from a member, however it didnt come with bolts,
can anyone who has one, please provide the lengths of the bolts needed to bolt this in? I've searched everywhere and cant find the information, only the thread pitch. and on the DIY thread they only specify "long bolts" "short bolts"
Any help is greatly appreciated!
Thanks!
Old Sep 5, 2012 | 09:44 AM
Pirana's Avatar
Is it a 4pt cage or 6pt cage, do you need the ones for the floor or the ones for the bars going back?
Old Sep 5, 2012 | 11:12 AM
Pssst's Avatar
4pt cage, sorry bout that. I need the ones that go to the floor and the back
Old Sep 5, 2012 | 11:47 AM
Mistaken's Avatar
Contact AP, Im sure they could send you a set for a small fee.
Old Sep 5, 2012 | 12:05 PM
Pssst's Avatar
Yea, Their kit is $65 and its not grade 8 Can get a grade 8 set from a hardware store for less the $10 just need length specs
Old Sep 5, 2012 | 03:04 PM
Mistaken's Avatar
Ah I see.
Good luck on the build, BTW.
Old Sep 5, 2012 | 03:12 PM
Pssst's Avatar
Ah I see.
Thank you! Started it and tuned it last night for the first time in months!
Old Sep 6, 2012 | 07:41 AM
Pssst's Avatar
up
Old Sep 7, 2012 | 08:12 AM
Turbo01s2k's Avatar
the legnth shouldnt matter much. Go find some random bolts around your garage and see if they are close to what you need, and then go get the right size and pitch. Id use 1.5 inch.
Old Sep 7, 2012 | 11:30 AM
Heres what I ordered from my local nut/bolt guy. Was going to buy from AP but his prices were too high
BTW, I dont think you should be using grade 8. The grade 5 spec is there for a reason. Grade 8's are very strong in tension but not shear. The grade 5 is better for this application from what I have learned
Dont forget to post up in the thread. We need ya!! https://www.evolutionm.net/forums/ev...ar-thread.html
Qty (12) 3/8 Dia x 1 1/2" long Grade 5
Qty (14) 3/8" nuts
Qty (14) fender washers
Qty (2) 3/8" Dia x 2 1/4" Grade 5
You will need some lock washers as well if your not using Nylok nuts (Also, If I remember correctly the qty 2 bolts at 2.25" were for the rear diagonal bars & not for foot pads
Joe
Old Sep 7, 2012 | 11:36 AM
Pssst's Avatar
Qty (14) 3/8" nuts
Joe
Thank you so much Joe!!! I have a spot reserved in that thread for mine I will certainly have pictures up this weekend of mine installed! I will be making a trip to the hardware store after work to pick these up. Thanks again
Old Sep 7, 2012 | 12:45 PM
honda-guy's Avatar
if you can, try to get some larger backing plates welded on the car then bolt the roll bar in.
