boost leak at pcv valve???
hey guys i got a bad leak at the pvc valve... i have put a new valve new band clamp with zip tie and it still leaks at 10 psi!!!
its leaking at the hose to pcv valve area.
any tips or tricks would be greatly appreciated!
I had the same problem with the oem pcv valve. Leaked at 10 psi. Bought a new one from Mitsu, and it leaked the same. Like you, I installed a check-valve between the pcv valve and the intake manifold. No more leak. That was about two years ago. I recently checked for boost leaks to 30 psi, and still no leak at the pcv!
