ACD in trunk oem pics
Old Sep 22, 2012 | 06:14 PM
Grimgrak's Avatar
Just curious what ACD factory installs look look on evo 8's and 9's
Old Sep 22, 2012 | 06:50 PM
Solenoid's Avatar
Veteran: Marine Corps
Forgive me mate. Im confused. Please explain
edit: I never knew the ACD was OEM in the boot
Old Sep 22, 2012 | 07:15 PM
TommiM's Avatar
ACD relocated to the trunk I believe. OEM configurations on put the pump in the dri side well area on certain eurospec evos.
Old Sep 22, 2012 | 07:17 PM
EvoIIIAj's Avatar
I will take a pic tomorrow. Mine comes factory in the trunk.
Old Sep 22, 2012 | 07:44 PM
AndyCT9W's Avatar
What exactly did you want to see?
Excuse the junk, moving it to storage.
Old Sep 22, 2012 | 09:44 PM
turbotalawd's Avatar
What about the pump? Any more detailed pics? Any pics of the lines running under the car to the transfer case?
I know you have a wagon but since we didnt get it here in the US im thinking it would be a tough install in a non-wagon.
Old Sep 22, 2012 | 10:04 PM
AndyCT9W's Avatar
I'll make an effort to get some more info and pics next time I have the car lifted.
ACD reservoir in the rear is standard on all JDM evos, sedans included.
Old Sep 23, 2012 | 04:45 AM
Grimgrak's Avatar
I am also curious if someone has a blow up diagram or a photo of the tcase where the fitting for the acd pump goes into. I can easily see a bleed nipple on the bottom of the case but not sure where it feeds into the top.
Reason for this is when I relocate everything into the rear it doesn't make sense to run the line all the way to the front of the car (rad area) if I can easily just hook it up directly to the tcase. From chasing the hard line on the front of the car it looks like it goes from drivers side front to passenger side, then onto the firewall up and possibly into the TC from there?
Old Sep 23, 2012 | 04:53 AM
Evo_AK's Avatar
Veteran: Air Force
The sitting is on the drivers side rear of the t-case. You are correct, there's a loooong hardline that goes from the pump, across the front of the car, wraps around the passengers side, follows the firewall, then into the t-case.
If you want to relocate it, you would just need to remove that hardline, and run a line straight back to wherever you mount the pump. I for one would def be in for some OEM part numbers to make it oem like that^.
Old Sep 23, 2012 | 04:55 AM
Grimgrak's Avatar
Any of our non usdm friends care to help out with that part #/diagram?
Old Sep 23, 2012 | 03:10 PM
TommiM's Avatar
A little bit of research turned this picture up..
http://www.ebay.co.uk/itm/MITSUBISHI...item564879abbc
Thats roughly about 12 ft of line and it looks like its goin to the passenger rear towards the well area. Im guessing 12 ft because thats how much ss line I ended up using and have it routed similar to this except for the bends towards the rear.
Old Sep 23, 2012 | 03:41 PM
RazorLab's Avatar
ACD pump and res is in the engine bay on USDM Evos 7-9. On non-USDM Evos 7-9 it is in the trunk since they have AYC.
Old Sep 23, 2012 | 11:51 PM
Grimgrak's Avatar
Also how hard is it to unscrew the existing ACD line from the Tcase in order to make a custom one to route to the trunk? Would I have to take the intake manifold off to get at it?
Old Sep 24, 2012 | 12:47 AM
Evo_AK's Avatar
Veteran: Air Force
Jack the car up and you'll see it from the bottom. It's pretty easy to get to. If your going to mount it on the drivers side, your gonna have to delete your emissions stuff.
Old Sep 24, 2012 | 10:23 AM
cmn130's Avatar
interesting
