ACD in trunk oem pics
Old Sep 24, 2012 | 10:41 AM
Grimgrak's Avatar
Since these pumps are known to fail to corrosion I plan to have the unit 100% inside the trunk. Why people chose to relocate them only to have the pump exposed to the elements is beyond me.
Originally Posted by Evo_AK
Jack the car up and you'll see it from the bottom. It's pretty easy to get to. If your going to mount it on the drivers side, your gonna have to delete your emissions stuff.
Old Sep 24, 2012 | 11:20 AM
Grimgrak's Avatar
I dont see anything but the bleed nipple on the bottom of the car. I'm trying to replace the hard line aka the feed line.
Old Sep 24, 2012 | 11:25 AM
Evo_AK's Avatar
Veteran: Air Force
If you can't find it, find the hardline that attachs to the pump, and follow the hardline back to the tranny. It runs underneath the bottom radiator core support.
Old Sep 24, 2012 | 01:15 PM
Grimgrak's Avatar
Found it looks like it goes up into the tcase via the downpipe area.
Old Sep 24, 2012 | 01:50 PM
Grimgrak's Avatar
Any one know how hot the add temps can get? Getting some local flex lines made.
Old Sep 24, 2012 | 02:14 PM
Evo_AK's Avatar
Veteran: Air Force
I think normal braided hose is good up to like 200*. Do you know the fittings your gonna need?
Old Sep 24, 2012 | 02:28 PM
fantrman's Avatar
Anybody know what maximum line pressure could be expected here?
Old Sep 24, 2012 | 02:58 PM
Evo_AK's Avatar
Veteran: Air Force
It's been said not much. I'm actually just thinking of trying to uninstall the hardline and straighten it out back to the drivers side. Should be long enough to reach.
Old Sep 24, 2012 | 03:09 PM
Grimgrak's Avatar
I heard its between 150_200psi hydraulic line is rated to 257f hope it's enough
Old Sep 24, 2012 | 04:23 PM
fantrman's Avatar
I'm thinking of relocating mine as well. I can't image the ACD line pressure would be anywhere near that or that the fluid temperature would be more than say 180f. It seems like regular SS braded hose would more than enough IDK.
Old Sep 24, 2012 | 04:44 PM
TommiM's Avatar
any ss braided line should be fine. I had a local hydraulic shop make me some line out their ss teflon lined stuff. IIRC the temp rating awas around 600 deg for this stuff.
Old Sep 24, 2012 | 04:53 PM
TommiM's Avatar
The hardline is routed up to the tunnel area and it turns from a hard line to a hydraulic rubber line with a banjo fitting. If you still have the head and manifold on the car it might be hard to see
Old Sep 24, 2012 | 06:45 PM
R/TErnie's Avatar
check out my build thread... I have a few pics of the ACD relocation kit I did.
Old Sep 24, 2012 | 07:42 PM
Grimgrak's Avatar
Wasn't your pump exposed to the elements still?
Old Sep 25, 2012 | 05:39 AM
TommiM's Avatar
I couldnt tell from the pics, but did you use a hard line or ss line? What path did you choose to route the line from the pump to the tc?
I mounted mine inside the trunk but have since went back and redesigned how I am gonna do it due to just not happy of the path the line is routing from the tc to the trunk.
PSA
Mar 30, 2017 12:37 PM
EvODavO
Nov 17, 2016 07:38 PM
BoostNY
Apr 4, 2016 06:00 PM
Wiznaz
Northeast Region
Jun 25, 2014 10:51 PM
carisma
Nov 29, 2004 02:49 AM
