catch can compressing?
Old Oct 30, 2012 | 08:25 AM
snafufx's Avatar
Short story, I noticed I had "grease" or some gunk under my car as I was checking for boost leaks. Thought it was my axle, everything was sealed tight. Come to find out, my catch can bottom blew off. I re-tightened it and everything seamed fine. A few days later, I go to check and my catch can looked "compressed" at the rubber, almost like a crushed up can...but with rubber.
My catch can is the Perrin (rubber/sealed), connected from the pcv valve->one way check valve towards can->input port on can. Output port on can->one way check valve facing towards intake manifold->intake manifold. This is correct isn't it?
Should I just replace it with a small open filter metal catch can? My other is a JMFab large open filter connecting to valve cover and intake pipe with no issues. I'm just worried the bottom of the perrin will come loose again and pop off. Has anyone else had these issues before? 2.3L block, Thanks.
Old Oct 31, 2012 | 01:04 AM
Evopwnd's Avatar
Yes I've seen this before. I went with a vented catch can setup.
Old Oct 31, 2012 | 02:22 AM
tscompusa's Avatar
if you're pressurizing your catch can then your check valve is not working or not going into the right direction. the check valve should not allow any kind of pressure from the intake manifold to enter into the catch can.. if it does its not setup right, and you will pressurize the can under WOT.
vortico
Jun 21, 2017 11:38 PM
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
Lgkaos
Sep 26, 2013 09:51 AM
AJsGenerX
11
Jun 24, 2013 02:15 PM
sabastian458
Dec 11, 2008 12:31 PM
