Boost leak test leak coming out here? (throttle body)?
Old Oct 30, 2012 | 01:34 PM
beasters's Avatar
The reason I am doing a boost leak test in the first place is because I recently bought the car and just installed a wideband gauge and running rich (10.0) at wot. Anyways can someone tell me what this is? I know I have air leaking at the biss screw but I also have air leaking from here and dont know what this is called or if this is common? btw I have already replaced the tb seals with mil.spec.
Attached Thumbnails Boost leak test leak coming out here? (throttle body)?-photo-5-medium-.jpg
Old Oct 30, 2012 | 01:47 PM
Macaroni's Avatar
Thats your IAC
Old Oct 30, 2012 | 01:56 PM
05blue8's Avatar
No that isn't, that's something else. It was only on a year or two of the throttle bodies, on the back side of it right? The IAC is an electrical module that has a harness plug in to it. It's the question mark piece right? That I think is the backside of the throttle plate shaft opening...I think. I leak tested a friend's RS and it also had a leak there. It was a couple years ago but I did something to stop it...if I recall there are a few small pieces in there so you have to be careful when you open it not to lose any.
Attached Thumbnails Boost leak test leak coming out here? (throttle body)?-whatisit.jpg
Old Oct 30, 2012 | 02:36 PM
beasters's Avatar
yes, this is the question mark piece that you labeled in your picture 05blue8. So I should remove the throttle body and take it apart? Anything I should order to replace it with like a seal or anything?
Old Oct 30, 2012 | 02:52 PM
Macaroni's Avatar
That's the back side of your throttle body shaft. Your seals are bad.
Old Oct 30, 2012 | 03:00 PM
beasters's Avatar
No its not. Sorry I looked at the picture with the question mark too quickly its actually below that, HERE
Old Oct 30, 2012 | 03:06 PM
Macaroni's Avatar
That's the coolant jacket for your IAC.
Old Oct 30, 2012 | 03:45 PM
beasters's Avatar
whatever its called its causing a boost leak.. how should i seal it? Does anyone else have this problem?
Old Oct 31, 2012 | 09:21 AM
beasters's Avatar
When I search online for an iac coolant jacket nothing comes up.. Anyone else have info about this leak I have?
Old Feb 16, 2013 | 05:41 PM
evoVI_PR's Avatar
This seems like a dead thread, but I have the same problem. Any update on this??
Old Feb 16, 2013 | 06:26 PM
latreille's Avatar
I used gray permetex silicone, worked fine for me.
Old Feb 17, 2013 | 11:18 AM
Czarcasm's Avatar
Is it a dead end hole? Nothing connects to it? I threaded mine, basicly put a plug in it with some teflon tape. Thats if you want to go that far
Old Feb 25, 2013 | 09:46 AM
evoVI_PR's Avatar
That plug has what looks like a small flapper inside, with a spring that limits its rotation. I have no idea what it does, I just wanted to get the leak sealed up.
Well the o-ring that seals that plug was stiff and worn. I replaced it with a thicker one I found, really had to struggle to get it to fit. Didn't get to drive the car much but it seems to have done the trick.
JCG
Old Feb 25, 2013 | 10:25 PM
vipevo9's Avatar
silicon does the job
Old Mar 21, 2013 | 12:18 AM
Nimpoc's Avatar
That's the access port to the bi-metalic strip to control course idle speed. I think it's acted on by the coolant flow through the throttle body. As the water heats it the valve closes up to reduce TB by-pass air. Mines leaking too.
