Crossmember not lining up with subframe! Help!
I recently sold my ams crossmember because I just got fed up with the vibration and noise, especially after cams. I bought an oem one and the holes are off by about 1/2"! I obviously can't move the radiator mount, so would loosening the subframe bolts move the subframe enough? Only reason I ask and not try is because I started to yesterday and the main subframe bolt just keeps spinning. I'm gonna get a nut splitter, and replace the nut but am I just screwed?
I should mention my car was in an accident with the previous owner and the radiator mount was replaced. I guess they welded it a bit far off! The ams one works because the hole that mounts to the subframe is slotted so it has room to move and the oem one doesn't.. help!
EGbeater
Jan 16, 2016 04:14 PM
deeman101
Oct 27, 2014 11:28 PM
swalltr207jg
Sep 17, 2014 11:16 PM
fireroasted
Jan 4, 2013 08:23 PM
