Different BOV
Old Nov 24, 2012 | 04:18 PM
HoPeLeS's Avatar
Question Different BOV
I have a stock BOV on my evo and am looking for a more ferocious sounding one. I don't want one that flutters and am having trouble finding one that is more prominent sounding. Any suggestions? Thanks
Old Nov 24, 2012 | 04:19 PM
k_sheanh91's Avatar
Check out the Tials, always a solid product
Old Nov 24, 2012 | 04:20 PM
cdmassee's Avatar
Ferocious?
Old Nov 24, 2012 | 04:23 PM
Wicked_White10's Avatar
Do you really need a new bov...?
Old Nov 24, 2012 | 04:38 PM
HoPeLeS's Avatar
I don't NEED a new one but WANT one that is louder but not over the top loud. The stock BOV is good but a little to quiet for my taste.
Old Nov 24, 2012 | 04:44 PM
Old Nov 24, 2012 | 04:47 PM
ak47po's Avatar
No matter what you drive, how old or new, diesel or petrol, our Fake electronic dump valve will give you that air dumping turbo sound you have been looking for without having to spend thousands of pounds on a turbo conversion. Until recently you would need a turbocharger to use a actual dump or blow off valve to create the sound of high pressure air been dumped into the atmosphere. Now using a High Output Marine speaker combined with MP3 Technology the EDV can recreate this sound perfectly and just as loud, if not louder than some turbo cars with a lower psi of boost.
Our Dummy blow off valve simulator works in perfect time as a real dump valve. ON a actual dump vale the pressure is released into the atmosphere when a gear change is made, this stops the spooling of a turbo and allows the valve to open. Our dump valve simulator works using a micro switch mounted behind the accelerator pedal. When you put the foot to the floor the system is activated and ready, as soon as you change gear you need to bring your foot off the accelerator, at this point the micro switch is released and the sound is played immediately and loud. There are no buttons to press or timing to keep, it really is that simple, and fitting is quick and easy too requiring no special tools or engine knowledge.
This is not a performance modification and therefore will not affect your insurance. However it may make the person about to race you think twice as you can rev the engine when the car is stationery and still create the dump valve sound.
Our XL Edition is the same as the standard edition but comes with another 80w Highpower speaker which dramatically increases the quality of the dump valve sound, bass and more importantly volume. Its a matter of just how loud do you want to go!
Old Nov 24, 2012 | 05:44 PM
WikdEvo's Avatar
lmao.. you do realize that your car has a maf right?
Old Nov 24, 2012 | 06:03 PM
adriano_917's Avatar
Tial Qr is the best!
Old Nov 25, 2012 | 11:54 AM
markjr11bravo's Avatar
Lolol @ "ferocious"
Old Nov 25, 2012 | 01:30 PM
luis!'s Avatar
Originally Posted by ak47po
lol!!
Old Nov 25, 2012 | 08:10 PM
chinolatino23's Avatar
hahahaha sabor-edv is hella good
Old Nov 25, 2012 | 08:49 PM
asu11's Avatar
If you don't need one spend money somewhere else. If you want a "LOUD" one, get a VTA. Probably would want to convert to SD also. Although if your tune is good, you can run VTA with MAF fine.
Old Nov 26, 2012 | 12:38 PM
AzEvo8urV8's Avatar
Ferocious lol, u trying to scare a cat??? I have a greddy BOV on mine sounds good, no whistle
Old Nov 26, 2012 | 01:33 PM
TiALSport's Avatar
http://youtu.be/u1jpjppnsei
no matter what you drive, how old or new, diesel or petrol, our fake electronic dump valve will give you that air dumping turbo sound you have been looking for without having to spend thousands of pounds on a turbo conversion. Until recently you would need a turbocharger to use a actual dump or blow off valve to create the sound of high pressure air been dumped into the atmosphere. Now using a high output marine speaker combined with mp3 technology the edv can recreate this sound perfectly and just as loud, if not louder than some turbo cars with a lower psi of boost.
Our dummy blow off valve simulator works in perfect time as a real dump valve. On a actual dump vale the pressure is released into the atmosphere when a gear change is made, this stops the spooling of a turbo and allows the valve to open. Our dump valve simulator works using a micro switch mounted behind the accelerator pedal. When you put the foot to the floor the system is activated and ready, as soon as you change gear you need to bring your foot off the accelerator, at this point the micro switch is released and the sound is played immediately and loud. There are no buttons to press or timing to keep, it really is that simple, and fitting is quick and easy too requiring no special tools or engine knowledge.
Our xl edition is the same as the standard edition but comes with another 80w highpower speaker which dramatically increases the quality of the dump valve sound, bass and more importantly volume. Its a matter of just how loud do you want to go!
{omg}
