Dont know...
Old Dec 23, 2012 | 05:33 PM
  #31
OPENA(671)'s Avatar
alright so i brought the car in and everything checks out fine...
what was done:
-compression test: 125,130,125,130
-fuel pressure test: 41-42 psi idle, 8-10 psi vac line open
-spark plug and wires checked good
-leak down test done
-no external leaks
-mechanic couldn't get any read on ecu. turns device on but no connection. why?
drove home fine. next day car wont start.
it cranks but wont start.
will post a video soon.
Old Dec 23, 2012 | 06:21 PM
  #32
OPENA(671)'s Avatar
Old Dec 23, 2012 | 06:24 PM
  #33
OPENA(671)'s Avatar
heres a link:
http://s1267.beta.photobucket.com/us...64255.mp4.html
battery? starter?
first time this happened
Old Dec 23, 2012 | 08:09 PM
  #34
Mao's Avatar
Mao
Check your sparks. I had the same problem too but a new set of sparks fixed it.
Old Dec 24, 2012 | 01:31 AM
  #35
mr. onetwo's Avatar
Could be your map sensor from the running video. When I had a jdm sensor in with no tune for it mine idled like that
Old Dec 24, 2012 | 02:08 AM
  #36
AWDBus's Avatar
Cam angle sensor?
Old Dec 26, 2012 | 04:38 AM
  #37
OPENA(671)'s Avatar
got the car running. yupp... it was the spark plugs.
replaced them and the wires.
question though, how does engine knock sound like?
hearing a low tapping i think between the fuel injectors and engine.
or are evo engines just naturally noisy?
let me know. a video would be nice if you got one.
thanks
Old Dec 26, 2012 | 04:52 PM
  #38
AWDBus's Avatar
Lifter tick is what you possible hear. 4g motors are very prone to it. They make a quieter set, but I am used to a 1g and the evo is very quite vs that.
Old Dec 27, 2012 | 08:43 PM
  #39
OPENA(671)'s Avatar
So is lifter tick is a bad thing?
And if it is, any remedies?
Old Dec 28, 2012 | 10:59 PM
  #40
AWDBus's Avatar
No, its not a bad thing, just annoying. The only fix it to get the no tick lifters. I think GSC made a set.
http://www.shopenglishracing.com/GSC...ishi-4G63.html
Heavy1976
Aug 31, 2014 09:02 PM
Ckeesee12
15
Mar 17, 2014 07:12 PM
SamFQ340
Feb 9, 2014 06:37 PM
Jake.barratt
Jun 13, 2013 12:08 PM
fsc0224
26
Oct 11, 2012 04:39 PM
