Need help with Gauges
Old Nov 29, 2012 | 10:41 PM
sest1412's Avatar
Hell evo members
I have been doing alot of reading about the evo since i got it about 8 months ago but couldnt find the anwsers i need, when i bought the car it came with 3 gauges volts, oil pressure and boost all 3 were working right and the all of the sudden the oil pressure gauge stopped working the needle points to the max psi idk know how to fix this, and then the volts gauge started to go crazy from 8 to 18 volts just back and forth like crazy, i was looking at the fuses and its hooked up to the cigarret lighter fuse and the boost gauge woks good.
Thanks for the help guys.
Old Nov 29, 2012 | 11:07 PM
adriano_917's Avatar
Check the wiring on the gauges and check the oil pressure sending unit.
Old Nov 29, 2012 | 11:22 PM
sest1412's Avatar
I have checked the wiring but i dont really understand it the only thing i know the power comes from the cigarette fuse i pulled the gauge pod but coulnt see any loose wires and the oil sending unit how can i check that i know were it is.
Old Nov 29, 2012 | 11:53 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
You are probably going to have to get up under the car. Look around the oil filter, the sending unit should look like one of these:
When you checked the wiring on the gauges did you check to see if they have a good ground?
Old Nov 30, 2012 | 04:33 PM
sest1412's Avatar
ill take picuters to show you guys how its wired, were can i get another sending unit? Autozone maybe.
Old Nov 30, 2012 | 04:46 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Who made the gauges? Are they OEM?
Old Nov 30, 2012 | 05:33 PM
PauLieP's Avatar
i would check the ground on them
Old Dec 1, 2012 | 12:59 AM
sest1412's Avatar
They are prosport gauges
Old Dec 5, 2012 | 05:38 AM
egis's Avatar
I have the same problem with prosport sending unit.i replaced twice that sender in two years and its dead again and needle stuck at max.I gave up and left it alone.
Old Dec 5, 2012 | 05:40 AM
whiteEvo08Y's Avatar
Buy new ones and throw out your prosport ones. See problems solved
Old Dec 5, 2012 | 10:36 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
If you're positive it's just the sending unit, you can get one pretty easily.
I found this one searching google:
http://www.fastwrx.com/prrebose.html
Old Dec 6, 2012 | 04:16 PM
S1lverBu113t's Avatar
Def check all of the connections like previous members said and also might want to get a new sending unit for the oil pressure!
doncarbone
Canadian
Aug 26, 2014 09:33 AM
himuraknshn3
19
May 21, 2014 10:32 AM
tokie
11
Jan 10, 2014 11:08 AM
lbcevo
Sep 10, 2013 09:06 AM
emotart
Dec 8, 2012 04:17 PM
