Possible to diagnose ACD without stock ECU?
Take a small wire and short pins 1 and 4 on the OBD-2 port, then turn the key to the "on" position. The ACD lights will flash to tell you what the fault code is. There will be a number of slow flashes, a small pause, then faster flashes. The slow flashes each count for 10 and the fast flashes count for 1 (for example, if you get 8 slow then 2 fast flashes, the error code is 82). If I remember correctly, pin 1 is the pin closest to the shifter.
Off topic but related to ACD - how will your evo ix drive like if you have a bad ACD or can you even drive it all? Does it have a clutch disk inside as well and will slip if its bad? What does driving with a bad or going bad ACD feels like?
Yes, the black one is the OBD connector. I don't remember where the pin count starts unfortunately. I had found it somewhere (on this forum I think). Maybe try searching for it. Otherwise I can try checking the service manual tonight in case it's in there.
Since I relocated my pump to the trunk and have bled only with a battery pack my acd lights have been coming on randomly... however today after I did the gas pedal down turn key on sequence pump bleed. It has gone by the entire day driving without coming on... Fingers crossed.
What was the proper way to bleed the unit? I had it on a booster pack and would turn the pump on then crack the bleeder screw for a few seconds(never went lower than the min mark), close the screw topoff/check the level and do it again.
I kept having air bubbles in the fluid (attached a clear tube for it to go in drainpan)
evosdad
May 15, 2013 04:40 AM
