evo 8 wiring problem p0335 HELP!!!!!PLEASE!!!!!!!
Old Dec 23, 2012 | 04:58 PM
chubvo3388's Avatar
Exclamation evo 8 wiring problem p0335 HELP!!!!!PLEASE!!!!!!!
2003 evo 8 will not start new crank sensor still throwing same p0335 code along with p0113 p0108 please help,also no fire or fuel checked all fuses except little black box in engine compartment fuse box that says front ecu told this was mfi rely which according to my diagram would make sense as it is wired to the crank sensor and others any advice would be greatly apprecited
Old Dec 24, 2012 | 07:38 AM
dastallion951's Avatar
Well If your gettin a p0335 code....crank pos sensor is a main sensor the ecu uses to help with timing......If the sensors bad or its busted off by the trigger plate down by the timing belt.... Then the car wont fire, id replace that then reset battery, to see if the other codes come back....good luck
Old Dec 24, 2012 | 10:30 AM
chubvo3388's Avatar
new crank sensor was installed.....still nothing checked grounds, connections,battery,,,etc
Old Dec 24, 2012 | 11:01 PM
heavens turbo's Avatar
p0108, map sensor, p0113, iat circuit high, p0335, crank sensor. i found one of the guys on the forum had a bad cam angle sensor with all these codes listed. he said that worked.
https://www.evolutionm.net/forums/ev...113-p0335.html
ihockey1
Jun 26, 2013 08:40 PM
OverBoostedEvo
Jan 21, 2013 02:45 PM
chubvo3388
12
Dec 23, 2012 04:41 PM
ride switch
Jun 21, 2010 05:45 PM
motoevo
Sep 8, 2007 06:44 PM
