change your own oil, voids warranty?
Old Feb 10, 2004 | 10:24 AM
mjones53's Avatar
I was told this, is this ture?
degrootdd's Avatar
It's not true.
Old Feb 10, 2004 | 10:27 AM
nastea's Avatar
keep receipts and upc's
UFO's Avatar
UFO
No, it is not true. Nor is it true that you have to use Mobil1. Nor is it true that you must use a Mitsubishi oil filter. According to the Magnusson whatever thingy act they can't do jack.
Old Feb 10, 2004 | 10:29 AM
Quickshift's Avatar
Yes they can void on warrenty basis for oil. Only if the car is prescibed to have a certain type of fluid in it. Like the Evo and only using synthetic. Use normal oil and kiss that warrenty goodby if they find out it was the cause of a problem.
Old Feb 10, 2004 | 10:30 AM
1QWKEVO's Avatar
why in the hell does the owners manual show u how to change your own oil... I hella told mitsubishi offf when they tried to make me buy their pit pass.. I made then walk through the owners maual and show me where it voids the warranty, they could't prove anything...
Old Feb 10, 2004 | 10:33 AM
silverEVO8's Avatar
Re: change your own oil, voids warranty?
The only way they can deny your warranty over the maintenance is if they challenge that you did not do it (correctly) and you cannot prove you did....
Save the receipts of oil, filters, etc. and keep a log of the service. You should be OK. I never go to the dealer for service but I do observed the service requirements and keep all records.
Old Feb 10, 2004 | 10:37 AM
Quickshift's Avatar
Yup do exactly what silver says and you will be fine. I do all my maintenance myself.
Old Feb 10, 2004 | 11:34 AM
Tak555's Avatar
so, does the evo require the use of synthetic from day 1??? i know with my impreza i was told not to use synthetic until between 7k and 10k miles in order to let the everything seat properly.
greg
Old Feb 10, 2004 | 11:42 AM
Kayaalp's Avatar
Oh God...not this again!!!
Greg, this issue has been covered in great detail on several threads on the forum. If you do a search for "break-in procedure" or something like that, you should find all the info you'd ever want...and probably wish you'd never asked!
Emre
Old Feb 10, 2004 | 01:26 PM
Tak555's Avatar
whoa, dejavue... i'm a n00b all over again!!!
thanks emre, i'll check it out.
greg
Old Feb 10, 2004 | 01:38 PM
f86sabre's Avatar
The products you use have to meet the specification called out by the manufacturer in the owener’s manual. As long as the brand of product you use meets the specification then you are fine.
Best wishes,
f86sabre
Old Feb 10, 2004 | 03:36 PM
Kayaalp's Avatar
greg
LOL. No prob.
Emre
Old Feb 10, 2004 | 04:05 PM
Cash Money's Avatar
I was told the same thing by a mitsu dealership, that only the certified "Evo" tech can open your hood... i argued about an hour with them, and they finally saw my way, but i won't be going there for my car after all that drama... and yeah, you gotta run synthetic from the get go... Mobil 1, Royal Purple, Redline... etc...
