Hid cable going from the lower beam to higher beam.
Old Jan 15, 2013 | 10:11 PM
tdt1805's Avatar
I have an 03 Evo 8 with the adjusting headlights. I reinstalled my headlights and my driver side headlight makes the sound like its moving but doesn't. The cable running from the Lower beam to the high beam doesn't turn. When I look at it on the metal gear the plastic piece is stripped out. Im wondering what part number it is and where to get it. Any help would be appreciated. I can turn the actual cable by hand but its hard and like I said you can see the one side is actually stripped out.
Thanks.
Tony
Old Jan 15, 2013 | 10:54 PM
llDemonll's Avatar
that cable doesn't do anything but move the high beam. I took mine off when I adjusted my headlights. low beams will still adjust fine without it
Old Jan 15, 2013 | 11:04 PM
tdt1805's Avatar
Demon when I adjust them from inside the vehicle the headlights dont change at all but yet my passenger side does. Cant figure out.
Old Jan 16, 2013 | 10:02 AM
llDemonll's Avatar
chances are the motor is shot on the drivers side them
have a friend stick his head down on the drivers side right behind the headlight and listen for any noise when you adjust them. if he can't hear anything then the motor isn't working
Old Jan 16, 2013 | 06:33 PM
tdt1805's Avatar
There is noise.
Old Jan 16, 2013 | 08:47 PM
llDemonll's Avatar
might want to pull the leveling motor off then and either have your buddy look to make sure it's turning and if so, make sure none of the gears are stripped. if you can hear it working there shouldn't be any reason it's not leveling the drivers side headlight unless a gear is stripped out
you're talking about low-beams only, correct? because i am. the only way the high beams will adjust is with that first cable i was talking about that i removed
mlouis
Feb 4, 2015 10:27 AM
Sivtec00
Jan 15, 2014 01:33 PM
Can Of Rockstar
Oct 27, 2013 01:55 PM
nekkidlad
Feb 21, 2013 01:37 PM
