Wheel bearing or drivetrain?
It is constant affected only by speed. On throttle, off throttle, cruise - makes no difference.
I think I'm going to go ahead and change out both rear wheel bearings and see how that goes, even if only one is bad its probably worth doing both.
I've put two new rear wheel bearings in and no change.
I've researched some more and worn pinion bearings in the diff make the same sound. In the process of removing it I found there is no play in the driveshaft but there was play in each of the axles at the diff. I also found some metal fragments (like tiny metal splinters) around the axle seals.
I'm yet to actually inspect inside the diff.
Almost sounds more like a creaking to me? My 05 evo was bought and has less than 30k miles on it and the front wheel bearing was shot. Possibly the rear. Oh well I ordered ceramic bearings hope it fixes the issue.
Right, an update.
So I removed the diff, when I rotated the pinion by hand it was very lumpy/chunky/bumpy, however you wanna describe it, it was not smooth at all. I sent it STM NZ and had it inspected.
The response was that the pinion bearing collapsed, they fixed it up and sent it back with the old/damaged parts (with a free chocolate bar, score!). One of the bearings was completely ****ed, see pics. Royally ****ed in fact. Now that it is back, I can turn the pinion by hand and it rotates smoothly.
Unfortunately it might takes a while to get it back in and running as I've got some more work to do before it hits the road again, but I will definitely post some feedback when I do.
My noise is very similar to yours, I have no change in turning either. I look forward to hearing back from your test, I don't have any baller mates with lifts. I'll be able to find someone who will be able to help, in time. I will do this if I don't diagnose it before I find one.
Final update: Diff is back in car and has been running great for a a couple months or so. I am planning on starting a thread that will look into what caused the failure(and maybe other evos).
ROB-80E
May 14, 2018 05:34 PM
deeman101
16
Dec 2, 2014 09:16 PM
MTRJunior
Nov 14, 2013 05:21 PM
