Idle RPM Drop, Rich AFR, then normal.
EvoM i need your help with an issues ive been trying to get figured out.
Keep in mind this happens mainly after Ive been driving for a while or if i went hard on in (Like a 3rd gear log pull).
So after i come to a stop and let it idle the RPM drops for a second and my AFR goes super RICH, then it goes to normal.
It happens very randomly and in no particular pattern.
I have a video & log if it helps.
MODS IN SIG
MODS IN SIG
i have a stock evo 9 BOV..
And yes i did a boost leak test and one of my injector seals (one going to manifold) was leaking under boost but didn't think it would affect idle due to no pressure build up.
closed loop idle. and it happens even when i put my stock map sensor on with a stock map
its been like this for a while now. but like i said it only happens if i get on it hard or after long drives..
I'm guessing its your front o2 sensor crapping out. If it happens on wot pulls (high heat) and long drives (constant heat) on the front o2. That's a stab In The dark though. Or maybe the iac.
Are you on a mini battery???
Can you hear the fan kick on then it does the sweeping and idle dip?
I had this issue and it was my fan kicking on and pulling voltage then my AFRs would dip. I switched back to full size and these little things went away.
I would log battery voltage and see if it dips when the AFRs start swinging. Or get it op temp then slam on the A/C full blast and see if it replicates the problem.
Like the other guy said, its when your fan kicks in. Mine does the exact same thing at idle, fan kicks in and idle drops sometimes almost to point of stall. Only does it if I have the heater/ac on, when it dips i switch the blower to off and idle jumps right to normal!
Maybe you could try driving the car till full operating temp, pull over and let it idle, turn the blower on to the first setting set to defrost then wait for the engine fan to kick in to see if it drops? Its really bugging me too now that I think of it, mine is definitely power drop when the fan kicks in with the heater on! Maybe my battery is on its way out as it is the original from 06 lol
