checking fuel pressure
Old Feb 6, 2013 | 04:34 AM
BoredDSM's Avatar
Cam and crank sensor will not always throw a code when they go bad. They are a two trip fail which means they have to fail twice to actually throw the light on. Yes, usually if the wiring is damaged it will keep the light on but there are very rare occasions when a damaged wire is heated up to much resistance. More than likely it is a cam or crank sensor.
Old Feb 7, 2013 | 12:26 PM
mr.evo_desi's Avatar
maf?
Old Feb 11, 2013 | 09:13 PM
slimjim1804's Avatar
Sorry if its been suggested, but perhaps a heat-soaked cam sensor?
Posted from Evolutionm.net App for Android
Old May 30, 2018 | 11:17 PM
BrandonIX's Avatar
I know its an old thread, but i need help. Same issue here! My thread below.
https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/748925-evo-9-studdered-then-died-crank-no-start-starts-cold.html#post11823510
Old May 31, 2018 | 02:47 PM
barneyb's Avatar
I though Boomba Racing made an adapter that fit between the rail and hose that took a gauge but I don't find it on their site.
Old May 31, 2018 | 06:39 PM
BrandonIX's Avatar
That seems to just convert it to AN threads, no port for a gauge. I suppose you can buy this piece and then a gauge setup to "T" into the fuel line and adaptor. But the only adaptor and gauge setup in 1 is from UltimateRacing. Im just trying to see what his fix was.
https://www.ultimate-racing.com/products/evo-viii-ix-fuel-press
Simon Pugmire
Mar 23, 2017 06:13 AM
Mrjafrancis
Dec 23, 2016 05:01 AM
Lombardi23
Apr 22, 2016 08:15 PM
iwantevonow
Jan 10, 2011 10:43 AM
antwon6420
Sep 7, 2009 05:55 PM
