Compression Test Question
Old Feb 11, 2013 | 07:05 PM
EvoIXPilot's Avatar
About to do a compression test following the DIY. On this step:
7. Crank the engine with the throttle valve fully open and
measure the compression pressure.
Standard value (at engine speed of 250 r/min): 1,128
kPa (163 psi)
Minimum limit (at engine speed of 250 r/min): 951 kPa
(138 psi)
Do just keep foot down on the gas while cranking it?
Old Feb 11, 2013 | 07:21 PM
adriano_917's Avatar
Just crank it until the needle stops, and dont forget to take the fuel pump relay out and all the spark plugs out.
Old Feb 26, 2013 | 06:11 PM
vmrevo9's Avatar
Veteran: Air Force
Ive been told to unplug the crank position sensor plug. That should prevent ign and fuel.
Old Feb 26, 2013 | 06:17 PM
ASTEPW89's Avatar
I know every time Ive done a compression test Ive unplugged fuel pump relay and pulled all spark plugs. The big thing is to make sure you crank each cyl the same amount of times to get accurate readings
Old Feb 26, 2013 | 06:48 PM
Raptord's Avatar
Great job to the 3 above me for not even answering the OP's question
Yes, just hold the throttle down.
Also, the service manual says to unplug the crank position sensor. nothing in there about the fuel pump relay.
Old Feb 26, 2013 | 07:46 PM
It doesnt say, but you dont want fuel on the cylinders while doing a compression test.
Old Feb 26, 2013 | 10:37 PM
studioface's Avatar
Or you can pull the ecu 20amp fuse also it's in the fuse box under the hood and what you are looking for is all 4 cyl to be near same it doesn't have to be the exact same numbers on all 4.
arpad
179
Feb 9, 2020 03:51 AM
evo4mad
May 5, 2015 06:22 PM
MR. EVO MR
Dec 25, 2010 02:55 PM
cec12789
Aug 8, 2009 01:35 AM
