aftermarket bushings?
Old Feb 11, 2013 | 07:21 PM
WikdEvo's Avatar
I recently purchases my evo 9 and i'm slowly going through it and making the changes that I want. Along the way i've found a few upgraded surprises that I didn't know the car had.
I was in the process of changing the hvac lights to match the gauge cluster and found that I had a works short shifter. I'm curious as to if these shifter plate bushings are aftermarket or stock though. Any help would be greatly appreciated. They are rubber though, so i'm guessing they are stock.
Old Feb 11, 2013 | 09:31 PM
llDemonll's Avatar
those are terrible pics
usually aftermarket are two solid pieces, one for between the chassis and the shifter housing, the other for between the shifter housing and the top of the bolt
Old Feb 12, 2013 | 05:37 AM
Ramen_Noodle's Avatar
Those are aftermarket pieces. The factory bushings are solid rubber, and they don't come out as easily as the two piece.
Old Feb 12, 2013 | 06:35 AM
WikdEvo's Avatar
This is the top bushing where the bolt and washer go into the shifter plate. Ill have to check again and see if there are the same type of bushings under the plate/chassis mounting points. Also, these are very flexible.
Old Feb 12, 2013 | 06:49 AM
Ace King's Avatar
Those look like aftermarket of some kind. The oem ones are definitely one piece (rubber). I had to use a flat head to pop mine out, they were wedged in there lol
WikdEvo
For Sale - Cars For Sale
May 18, 2016 08:38 AM
WikdEvo
Aug 22, 2015 07:43 PM
WikdEvo
May 31, 2015 05:34 PM
WikdEvo
May 26, 2015 09:33 AM
WikdEvo
Aug 28, 2013 05:25 PM
