Wastegate muffler
Old Feb 12, 2013 | 07:36 PM
phrequenc's Avatar
Wastegate muffler
http://www.lindseyracing.com/LR/Pors...A-951-WGM.html
Anyone ever go with something like this before? Only thing I found with google is trucks and Porsche using it. No issues with boost creep or anything either..
I don't wanna route my wg to the dp I did some googling and people have said it really affects performance.
Only other option I think is a lawn mower muffler
I have a TiAL 38mm
Old Feb 13, 2013 | 11:39 AM
phrequenc's Avatar
Nothing?
Old Feb 13, 2013 | 11:45 AM
boosted91t's Avatar
Reroute it into the down pipe, if the merge is done correctly there will be no issues. The issue will arise if the recirc tube is merged at a terrible angle and creates unwanted turbulence.
Old Feb 13, 2013 | 12:00 PM
phrequenc's Avatar
So, what's the optimal angle? I have an ETS 35r kit
Old Feb 13, 2013 | 12:10 PM
llDemonll's Avatar
Call ETS and ask
Old Feb 13, 2013 | 01:34 PM
BDecker9's Avatar
MAP Sells a recirc'd wastegate I think. ETS makes one also. I'd call ETS first and then if they can't help you, call MAP
Old Feb 13, 2013 | 02:08 PM
Duo Maxwell's Avatar
This, unless you are seriously looking to experience the sound of a wastegate with a tiny muffler on it.
Otherwise I don't really see the point.
Old Feb 13, 2013 | 02:29 PM
phrequenc's Avatar
Re routing will always take away power.
Old Feb 13, 2013 | 04:06 PM
wazzelby's Avatar
Where are you getting this information from? I strongly disagree. If done right, you won't see a difference in performance. The problem is people using off the shelf re-routed O2/downpipes. A properly routed recirculated setup doesn't create enough of a restriction to lse you power.
Old Feb 13, 2013 | 04:12 PM
phrequenc's Avatar
Which is the "proper" way to do it? I called ETS they don't have anything that reroutes
Old Feb 13, 2013 | 04:13 PM
10isace's Avatar
Good to know. I'm thinking of going recirculated with a T4 TS.
Old Feb 13, 2013 | 04:17 PM
10isace's Avatar
Really? I could have sworn they had a pic of one on their site before they updated it. I'm checking a few sites now.
Old Feb 13, 2013 | 04:19 PM
10isace's Avatar
Old Feb 13, 2013 | 07:24 PM
phrequenc's Avatar
I spoke to mike he said no... Gonn have to custom do something... Still think the muffler is a better option though
Old Feb 13, 2013 | 10:17 PM
Grimgrak's Avatar
Dont let us stop you, go do it and post results/pics.
