Can anyone give me the specs on a Lancer Evo 3?
Old Feb 28, 2004 | 08:03 PM
ADVAN's Avatar
Well i have this evo imported from japan, actually it has an evo 2 skirt and bumper but have an evo 3 rear wing. i look at the chassis# its a CE9A, now i know its really an evo 3, but is there a big difference in engine and performance between evo 2 and 3
Old Feb 28, 2004 | 08:15 PM
ADVAN's Avatar
Old Feb 28, 2004 | 10:46 PM
Evo8DownUnder's Avatar
No theres not. The big difference in performance and engine was between the 1 and 2. The differences between the 2 and 3 were mainly cosmetic.
I've got a whole book on differences between the Evo Lancers all the way up to the 7.
Old Feb 29, 2004 | 06:18 AM
ADVAN's Avatar
i know its an off topic can, but can you tell me the difference in the chassis or body of an evo 3 and 95 lancer, voz i hav this 2nd evo 3 imported from japan for $2,000, and i want to know if the parts will be bolt on or not, tnx
Old Feb 29, 2004 | 04:12 PM
Yogi_B's Avatar
Not much difference between engines in the evo2 and 3, only major difference is the compression ratio. Evo2 = 8.8:1 evo3= 9.0:1.
As for the evo3 and 95 lancer, the engine and gearbox should all bolt up.
It's just getting the rear diff in that causes a problem, as the fuel tank in the lancer will be sitting right where the diff should be and also the chassis itself needs to be modified to fit the rear diff.
Also I think the evo3 chassis will be stronger than the lancer chassis.
Fitting the evo3 stuff into the regular lancer can be done but it will required a lot of work and money.
Old Mar 1, 2004 | 02:33 AM
Agreed. Pulling stuff out of a GSR and replacing it with Evo bits is easy, but going from FWD to 4WD will cause you problems that may not be worth the effort.
Old Mar 1, 2004 | 07:48 AM
wreckleford's Avatar
No, what the guy said earlier is wrong. CD9A is Evo I only. CE9A is Evo III and III.
Old Mar 1, 2004 | 07:51 AM
Originally posted by littleDEVILbike
Are you sure that's an Evo 1? Cause I'm all about about Evo's no matter what year... I love .
That car is definitely an Evo I.
The year of registration is not 1994 either. The licence plate is a K registration (starts with K) which is for cars registered between August 1992 and August 1993.
Old Mar 19, 2004 | 12:36 AM
tenji's Avatar
its an evo like mine...
however its probably 1st registered in the uk in 1994 hence it becomes a 94 like mine is registered on the roads in australia as 95 model
Old Mar 19, 2004 | 12:39 AM
tenji's Avatar
evo 1 and 3 have similar internals
evo 3 has a better turbo than 1 and 2
evo 2 can run higher boost it loves it
evo 3 has a different ecu to evo's 1 and 2
and for those who think that the evos have forged pistons they dont... i dunno bout the later models but 1,2 and 3 wise none have forged pistons
Old Jul 6, 2009 | 07:59 PM
KevinEVOII's Avatar
i love my evo 2 up here in canada, fast. but i notice there tannys SUCK compared to a gtr or even a silvia. i wish that mitsu didnt skip out on that
Old Jul 6, 2009 | 08:09 PM
tortyklubevo's Avatar
Hope this helps a lil bit
http://en.wikipedia.org/wiki/Lancer_Evolution
Tobra
Lancer Tranny/Drivetrain Tech
Jun 3, 2017 08:17 PM
ichris1120
Lancer Engine Tech
Jul 19, 2016 08:04 AM
rvcaman
Jan 24, 2010 09:19 AM
drmosh
Aug 19, 2003 11:01 PM
M3 STYLELAB
Lancer Engine Tech
13
Mar 5, 2003 02:10 AM
