Brownish color coolant
Old Mar 4, 2013 | 09:15 PM
Viegasjuice's Avatar
What about the fact that my plugs foul really fast? They get black but the tip still shows white? Is that due to my system being rich since i need a tune?
Old Mar 5, 2013 | 01:44 PM
BEKevo's Avatar
In general, white means lean, while brownish/ gold ---> black distinguish's if the engine is running a normal AFR to a rich AFR.
Old Mar 5, 2013 | 01:49 PM
ProPilot04's Avatar
1. There are millions of reasons for a plug to foul, and foul can mean a million things. If you type "How to diagnose spark plugs" into google, you'll find a myriad of information including pictures, that, as they say, will be worth a thousand words.
2. You mentioned that you've only had this car for a short time. How did you check to see if there was coolant present in your oil? Did you do an oil change, or did you check via the dipstick? Because you're going to want to do an oil change either way since you don't appear to know the history of the car. I might even suggest an oil analysis, but thats on you.
3. If the coolant in the reservoir is odd colored, I'd want to know why. The FIRST thing that comes to mind is... someone has put the wrong coolant in the car. This may not be it, but I'd probably change it anyway. Read... change it. I don't believe in flushing.
If there IS a problem, or some debris kicked up or whatever, then this would only help.
When you say that the coolant in the rad looks fine, there could also be a blockage somewhere within the radiator that is isolating fluid, so you'd need to realistically start with checking the oil, by changing it, and the I'd probably change the coolant as well.
Old Mar 5, 2013 | 02:36 PM
Thanks for the detailed response, ill do all of the above. When you open the radiator cap the fluid looks greenish transparent like it should. Ive only check the diptsick and theres no signs of coolant in the oil, just the coolant reservoir is dirty. I will change all fluids.
TxFAkuma
Sep 14, 2016 02:40 PM
LAN_EVO
Feb 23, 2012 05:22 PM
EvolNinja
11
Feb 26, 2009 09:33 PM
Mr. PSSsSt
May 21, 2008 08:16 AM
nnorris7413
16
Jun 28, 2005 05:34 PM
