Notchy shifting GONE!!!!!
Old Feb 15, 2004 | 04:39 PM
  #31
MYEVO8U's Avatar
Good to hear your results. I just ordered both the 8pc, 2pc and the turbosmart MBC from LancerShop.com. I have read the instructions and it sounds like a piece of cake.
Main reason I got them is beacuse of the great results I got from the Symbroski (spelling) shift kit on my '99 GSX. Install on the GSX was a snap. And from what the instructions look like they are almost the same.
I can't wait to Install these things.
Old Feb 15, 2004 | 05:06 PM
  #32
ChrisS.'s Avatar
I might of missed it, but how much $$
Old Feb 15, 2004 | 06:39 PM
  #33
MYEVO8U's Avatar
it's like $30 each kit + S&H
go to lancershop.com
click on Clutch - Trans
go to bottom of page
It's fairly easy
Old Feb 15, 2004 | 06:51 PM
  #34
jess's Avatar
when the car was newer it was notchy, but noticed after 6k miles it got smooth and even smoother now with 10k miles. still have the stock clutch and tranny. it gets better with age
Old Feb 15, 2004 | 11:13 PM
  #35
oak2207's Avatar
So will just doing the 2pc make a big imporvement? I really don't wanna undo the shifter assembly. Also, any impacts on warranty?
Old Feb 16, 2004 | 05:25 AM
  #36
xtnct's Avatar
Originally posted by xtnct
What is an under hood bushing? Is that an engine mount bushing? There are lots of bushings under the hood - never heard this term before.
Old Feb 16, 2004 | 12:42 PM
  #37
EvolvedDSM's Avatar
Originally posted by mikec
The 2-pc kit replaces the linkage bushings in the engine bay.
Old Feb 16, 2004 | 12:45 PM
  #38
oak2207's Avatar
Can anyone comment on JUST the 2pc? Is it worth it or should I really do all 10 pc? I also do NOT wanna screw w/the warranty, I need it to remain intact.
Old Feb 16, 2004 | 01:53 PM
  #39
SinCityEvo's Avatar
Wow, you can look right down at it by looking behind the battery. You can easily reach it w/o removing anything. After looking at it, there is a metal ring on the outside around the rubber on the inside, so it does not look like it will make a big difference. The shifter in this car i think is very good compared to many others I have driven. For $30, it may be worth a try and easy to do.
Old Feb 16, 2004 | 02:32 PM
  #40
Compjoc's Avatar
How do you get the stock rubber bushings off the shifter assembly? I was looking at them when installing a short shifter. I don't see how to get them out other than cuting them out.
Anybody replace bushings on the shifter yet?
Old Feb 16, 2004 | 02:33 PM
  #41
Deceit's Avatar
The rubber bushings holding down the shift assembly? They pop right out, just use a screw driver.
Old Feb 16, 2004 | 02:50 PM
  #42
silvrevo's Avatar
Ya, someone needs to post a picture of installing the shifter bushings,,,,, i just ordered the 2 sets today!!!!!
Thanks
Old Feb 16, 2004 | 04:57 PM
  #43
ttiscio's Avatar
Shifter Bushings
Don't sweat it, really. The shifter bushings are easy as pie to install. If you put in a short shifter this will be nothing to do. The kit comes with easy to follow instructions.
Old Feb 16, 2004 | 06:04 PM
  #44
evo81's Avatar
there's a great step by step on removing the bushings at www.evomoto.com. they also have a lot of other great advice in there tech section.evomoto rocks
Old Feb 16, 2004 | 07:41 PM
  #45
Compjoc's Avatar
Cool, thanks guys.
