Fuel pump upgrade? Yes or no?
Old Mar 9, 2013 | 06:28 AM
ThatOneKid's Avatar
Originally Posted by Viegasjuice
I agree, but i bought the car like this. So im wondering if thats the reason im having white smoke at idle and during cold WOT
No, that shouldn't be the reason. The byproducts of gasoline burning are carbon dioxide, and water. Youre seeing water vapor that condenses out of the cold.
Old Mar 9, 2013 | 06:54 AM
ctfpevoVIII's Avatar
I wouldn't recommend going WOT when the engines cold you should allow your fluids /coolant and especially your oil to get up to temp.
Old Mar 9, 2013 | 06:58 AM
elim0's Avatar
there are a few other brands other than walboro. deutchwerks or something ..
YES def get a fuel pump + tune ! .. fuel pumps are cheap and are cheap insurance ! running lean is the last thing you want
Old Mar 9, 2013 | 07:09 AM
itsmrrizz2you's Avatar
You may be running. A little lean I'd get a 255 and some fic 850
Old Mar 9, 2013 | 10:04 AM
DJ_Sky3's Avatar
Can't go wrong with a bigger fuel pump if you have the injectors to handle it otherwise you will basically just be bending your stockers over and giving it to them in a way nobody likes it lol..
Old Mar 9, 2013 | 12:26 PM
Viegasjuice's Avatar
Any guess what the issue is? My coolant looks good. Oil looks good too so wonder if its a headgasket. I hear catless cars can produce white smoke.
Old Mar 9, 2013 | 12:27 PM
Lol will do. How about a walbro 255 with 880 injectors?
Old Mar 9, 2013 | 11:29 PM
DJ_Sky3's Avatar
For any fuel system upgrade, a fuel pump is always the first thing I do (minus having the gear to tune).
A wally 255 sounds great but if you are going to by injectors and tune it never hurts to go bigger than smaller. 880's are a decent size but if you plan on going any more you might want to buy a little bigger (like around 1,000cc's)
Old Mar 10, 2013 | 01:04 AM
Would injectors that size be ok for my setup
Old Mar 10, 2013 | 08:06 AM
jager89's Avatar
Look into some I.D. 1000's, or as previously stated some FIC's or anything around that. Gives you plenty of room to play with for the future depending on your goals.
Old Mar 10, 2013 | 12:10 PM
warstang27's Avatar
880s are a dime a dozen i paid 130 for my set and is more than you need. also not sure when you last replaced your plugs but that could be a problem esp with your tune being out of whack. also with your mods you dont need a bpr8, id run a bpr7es gapped to .020. most importantly id get a tune asap
Old Mar 10, 2013 | 02:18 PM
I have bpr8es gappes at .020 and they foul super fast!!
Old Mar 10, 2013 | 05:31 PM
Originally Posted by IE_Evo22
Just get a Walbro 255 and ur good.
Would that help with this damn fuel cut/boost cut whatever im experiencing.
Old Mar 10, 2013 | 06:57 PM
Tuxevo's Avatar
Holy crap! How many threads do you need to start in which people provide you numerous reasons to get a tune? Why are you not sensing a common theme? Go get a tune before your car explodes. If you have a real mechanical problem, need a fuel pump, need bigger injectors, need to replace head studs, resurface your head, purchase a pink air freshener or whatever else may be required A COMPETENT TUNER WILL BE ABLE TO HELP YOU!!!!! Lastly, if you're wondering how to pick a capable ttuner, don't start another thread. SEARCH!
PS here's a smiley face so you know I'm friendly
Old Mar 10, 2013 | 07:06 PM
New owner bug...but your right.
