Losing power while driving?
Old Mar 16, 2013 | 04:23 AM
jordanwince's Avatar
Hey guys,
I searched around and couldn't really find anything that relates so let me ask.
We recently did a clutch job on my 8. Everything was just fine before. Gt done ad everything ran fine. I recently took it out and by the time I got home the instrument panel was real dim. Turned the switch all the way up. Still not bright. I then stalled out and tried to start it and it was dying admit was turning over. Finally kicked and parked it...
This morning it started fine but sorta slowly. As I was driving today the srs light and abs light came on, CD player died, interior lights got even dimmer. Almost out completely, and the car was idling at 2k. So I took it home.
Does this sound like a ****ty battery to you like it does to me? It's small stuff that I can fix but would bother me all day at work if I didn't talk to others about it.
Help me
Old Mar 16, 2013 | 04:36 AM
racingmagic's Avatar
It could be alternator. Coz when mine when out on me that what happen. When I turn on the ac it won't start I thought my ac compressor broke but when the car died n leave me stranded on high way. Lucky my friends has a Evo too so I just borrowed his battery n drove it home.
Old Mar 16, 2013 | 05:20 AM
Ill check into that as well. Thanks man
Old Mar 16, 2013 | 07:50 PM
Check terminals ad tightened them. Still to no avail. I really do not want to accept it is the alternator
Old Mar 16, 2013 | 10:34 PM
evo_yoshi15's Avatar
Battery Terminals Or Alternator
Old Mar 17, 2013 | 01:14 AM
Jimmy Javelin's Avatar
+1, I thought I had a faulty alternator turns out to be just a loose bat terminal.
Tighten them down and go for a spin.
Old Mar 17, 2013 | 04:27 AM
Yea. Has to be the alternator. Those terminals are tight as ****
Old Mar 17, 2013 | 05:24 AM
Royal Evo's Avatar
I suggest you check the voltage output. With engine not running, it should be around 12-12.5 Vdc. Then start your car (hope there is still enough juice to crank it) and raise RPM a little bit, measure again, it should be around 13-14 volts ( 13.8-14.2 ). So, it could be your battery or your alternator. If alternator is charging, then you need new battery. But since you were able to start and drive the car- it seems you were just running on battery with just enough juice to start it and drive and then it eventually died since nothing is charging it.
Old Mar 17, 2013 | 08:39 AM
jsayers's Avatar
mine did this too a few times after multiple alt changes. ended up being because the harness coming off the alternator was starting to break and was getting a bad connection
19.5PSI
Jan 29, 2016 07:19 AM
delta6force94
Jan 20, 2016 05:43 AM
SyHS
15
Aug 12, 2015 10:30 PM
hooliganSKATE
Jul 16, 2015 06:21 AM
mykep83
May 18, 2015 04:15 AM
