Power steering whine/heavy steering
Hi all,
after some help/advice.
basically i fitted an aftermarket power steering tank and pipes, thought id bled the system but when i turned the wheel and the pump whined loudly.
i have now put the original back on turned it lock to lock a couple times and it was quiet.
now tho when the system is cold its fine, as soon as it heats up the pump whines and steering is very heavy when turning the wheel when stationary.
any advice? i have some people saying its not bled, and a tuner saying its the pump thats faulty.
why would it be fine cold but not when hot?
help please
help please
if its not bled it will be hard and pulsate kinda, The whine could be a bad pump. Does it whine at higher RPM? Yes it could be a bad Pump, Id top it off all the way, turn the wheel both ways totally 3 times at 2k RPM then see what it does.
doesnt whine at all when not moving the steering, only when turning the wheel at idle, if i give it revs the steering is normal and no whine,
air in the system/incorrect fluid/Low idle/restriction in the lines or dirty fluid/Faulty pump
Is the Resivoir Aftermarket? does it hold enough fluid and is the feed on correctly?
Thats where i would start.
level on the pot is high if anything.....
what type of fluid did you use? What is your idle? If the belt is slipping at idle it will whine and squeal and not work. Why it works when cold seems like a fluid issue.
I dont use Power steering Fluid or ATF, I use a AW32 non Detergent.
IVE used an "own brand" but its the dexron III. the whine only happens when i turn the wheel, at all other times its silent
when hot, its v heavy to turn and noisy and noisy at lock.
if i rev it the pitch increases with the revs.
