Shaking engine?
Old Mar 17, 2013 | 10:41 PM
Viegasjuice's Avatar
Shaking engine?
Cold start up engine shakes, is this normal...at al?
Old Mar 17, 2013 | 10:53 PM
Pal215's Avatar
If its excessive shaking, Sounds like worn out Motor Mounts. It is normal for the engine to produce more vibrations upon cold start.
Your engine should never be rocking on it's mounts at idle. Just a slight vibration.
-pal215
Old Mar 17, 2013 | 11:04 PM
-pal215
Ahh I was I could disinguish the differencr between a shake or vibration lol, hard to tell over internet what im tryin to describe.
Old Mar 17, 2013 | 11:54 PM
djdnav's Avatar
the difference is this:
-if it feels like it's running rougher then it's probably the emissions stuff warming up the engine
- if it feels like something is broken, then it might be
Old Mar 19, 2013 | 12:22 AM
BEKevo's Avatar
Normal. Judging by your original post..
Old Mar 19, 2013 | 01:14 AM
Looks like a back and forth shake.
Old Mar 19, 2013 | 01:23 AM
sickness06's Avatar
Does the whole motor physically shake or can u just feel it in the cabin ....and is it only when it's cold
Old Mar 19, 2013 | 04:05 AM
The motor physically shakes. Yes only when really cold
Old Mar 19, 2013 | 04:47 AM
Kian's Avatar
How cold. It can take a minute for the car to warm up in cold weather. That's normal
Abnormal things could be spark plugs or maybe dirty throttle body?
Old Mar 19, 2013 | 04:57 AM
Yes its only for a little. Looks like everything is ok from the responses.
Old Mar 19, 2013 | 04:58 AM
To add, cold as in 20 degrees.
Old Mar 19, 2013 | 07:26 AM
mattjung2003's Avatar
I m having the same issue.
Old Mar 19, 2013 | 09:16 AM
elim0's Avatar
my engine shakes too, but i have cams. i installed a front Motor mount, helped a bit but now the whole car vibs a bit lol .. the other mounts look okay and no excessive shaking around the mounts specifically.... so i just left it as it is
Old Mar 19, 2013 | 10:46 AM
I have gsc s2 cams aswell
Old Mar 19, 2013 | 10:52 AM
Kian's Avatar
Yup that's the problem. I have some s2's also and with a cold start the car will shake my gooch numb
