retune
Old Mar 30, 2013 | 11:25 PM
team714's Avatar
retune
Going back to rre for a retune for a high flow cat, injectors for e85. im currently running the cobb intake. should i go back to my kn drop in for the tune?
Old Mar 31, 2013 | 07:57 AM
Abacus's Avatar
If the cobb is an open element and you have a 9 with a stock turbo,( less then 350-400
) I would personally go back to the stock airbox and dropin. There is about a 20 degree difference in IAT temp from a box to an open element. A lower inlet temp is going to more detonation resistant . I remember reading an I/C thread and inlet temp was discussed with an open filter.
If the ACD pump wasn't in the way then a filter/snorkel in the fenderwell would be ideal.
Edit*
Just saw that you are on E85. Go with an open element because it should make around 400whp and the stock box is a restriction at that point. Plus the cooling properties of E85 are amazing. It will make as much power and take timing right up until it pushes the headgasket out of it. I'm sure they will be conservative and it will make great power.
Old Mar 31, 2013 | 08:40 AM
misterevo8's Avatar
open element. so you dont have to retune later and you are going e85.
Old Mar 31, 2013 | 12:21 PM
team714's Avatar
Do you guys experience the cel flash when the intake flutters. It seems like the intake is causing to cel to flash. thats why i was thinking going back to stock.
Old Mar 31, 2013 | 06:52 PM
misterevo8's Avatar
hmm. run a scan on it. have rre look at it bro.
Old Mar 31, 2013 | 07:06 PM
evo8426's Avatar
If it is flashing consistently then the car needs to be retuned. The flash is indicating the car is knocking which is not a good thing, that is if the car is tuned on a tephra rom.
acid7711
10
Jul 28, 2016 01:25 PM
MisterRegato
Nov 9, 2015 01:26 PM
eliminator 429
Feb 28, 2011 12:23 PM
05VIII
Dec 2, 2010 06:43 PM
Cyloc
Southeast Region
43
Sep 2, 2008 03:38 PM
