BAD MAF? evo 7
Old Apr 2, 2013 | 12:49 PM
envdevo9's Avatar
BAD MAF? evo 7
Last week i was replacing one of the upper intercooler piping, all oem othere then my air intake, which I took off to clean the inside of the pipe. Put everything back together, started the car. Started right up but 10sec later rpm's went up to about 2,200, stayed there for a few seconds. Then started to act up where it would rise up and come back down repeating. I didn't know what it could be, for some reason I decided to unplug the MAF, that moment it stopped doing that, went back down to normal idle. But was running really rich. Maybe bad maf?
Old Apr 2, 2013 | 02:31 PM
ProPilot04's Avatar
It could be a bad MAF.
1. When you installed the UICP, did you do a complete boost leak test?
Old Apr 3, 2013 | 03:17 PM
envdevo9's Avatar
Don't think its a vacuum leak but I think ill try and swap out the maf with someone I know.
Old Apr 3, 2013 | 03:37 PM
ProPilot04's Avatar
Why do you not think it's a boost leak? You just swapped a UICP. If the car was working fine before, and that's the only thing you changed, then that's where the diagnosis starts.
Get a spray bottle, and an air compressor, and check for leaks.
The MAFs job is to detect the correct amount of air, and tell the ECU how to handle it. Your car runs fine, but you just completely changed the amount of airflow the ECU and MAF are used to seeing. Did you disconnect your battery at all, because that will let the ECU re-learn. Otherwise, if you re-connected the MAF while the battery was still connected, you could've easily arc'd it.
1. Do a boost leak test and report back.
Old Apr 3, 2013 | 04:02 PM
envdevo9's Avatar
The battey was connect, did it mess the maf u think? And ill look into the boost leak this weekend.
Old Apr 3, 2013 | 04:22 PM
ProPilot04's Avatar
Well... anytime you're connecting a hot circuit to a computer, you're asking for trouble. But you were having the problem BEFORE you pulled the MAF. So it's possible you could've fried it, but if nothing else has changed then start with a BLT.
The last couple cars I put IC pipes onto idled pretty wonky for a couple of minutes before it got back to normal, and after a couple miles of driving in and out of boost, it was no issue at all.
So I would probably:
1. Do a boost leak test (which is part of installing any component related to the turbo).
2. Disconnect the battery for a few minutes (or while you're doing the BLT).
3. Re-connect it, fire the car up, let it idle for a couple of minutes. After it seems to stabilize, go for an EASY drive.
4. The get it into and out of boost a bit to let the ECU work out the maps. (Don't go full boost right away in case the car leaned out)
Boom. Done.
Old Apr 5, 2013 | 04:14 PM
envdevo9's Avatar
Before I took the maf off the car, the car was running fine, problem stared when I put everything back together. I might have damaged the maf some how. I'll look into the BLT.
Old May 5, 2013 | 12:28 PM
envdevo9's Avatar
Looks like it was the maf, changed it with a used one and started up good and ran normal.
Prime12
May 1, 2017 05:55 PM
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
NFSLancerRA
May 31, 2014 06:54 PM
NZEvox
Feb 10, 2013 01:40 AM
