Weird AFR Readings
Weird AFR Readings
...during idle. This is from a semi-warm start.
Outside temp is around 45 degree. I've read AFR at idle should be around14.7-15ish. As you can see, mine sometime dips into the 16-17s. Is this typical? I have regular bolt ons and no engine mods. This was happening before installing larger injectors.
Thanks.
Thanks.
Ok, found out it can be the EGR solenoid gone bad. I read it is underneath the intake manifold. So I'm assuming on the side towards the firewall. What's the best way of getting to it? Do I need to go from underneath the car?
