Is this catch can setup ok?
Old Apr 12, 2013 | 12:34 AM
jaredh's Avatar
I know there are a thousand catch can install threads, but I want to check to see if there are any problems with the way I am thinking about running it. I'm not confident.
I ordered this one. Looked nice. I was going to remove the pcv valve and run a hose from there to the catch can which will be vented to atmosphere, then plug the intake manifold. Also run a hose from the valve cover breather straight to the catch can and plug the nipple on the intake. Thanks!
Old Apr 12, 2013 | 05:02 AM
djdnav's Avatar
Just remember you'll need a bung on the vc if you remove the pcv
Old Apr 12, 2013 | 06:46 AM
chu's Avatar
chu
Read the last few pages of this thread for some great info.
https://www.evolutionm.net/forums/mo...catch-can.html
Old Apr 13, 2013 | 04:29 PM
jaredh's Avatar
ya i hadn't seen that thread yet. i think i will try this setup. then maybe i might not like it and will change.
jaredh's Avatar
i cant just plug into that? do you know how could go about putting one on?
Old Apr 13, 2013 | 07:14 PM
djdnav's Avatar
You can buy -an fittings from STM for like $10 and screw on a smooth adapter to attach a rubber hose. When you remove the pcv valve it'll be an empty hole
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
mrfred
Jul 2, 2015 05:46 AM
David Buschur
Aug 12, 2012 07:39 PM
Gordian79
22
Jan 31, 2012 04:37 PM
David Buschur
Nov 23, 2010 05:57 PM
