Notchy gears or grinding?
Old Apr 16, 2013 | 10:06 PM
Viegasjuice's Avatar
05 evo 103.5k miles..only thing clutch wise is braided clutch line. When tryin to shift really fast it kinda grinds/whines most noticeably going into or downahiftin into fourth... This does not happen if i shift normally or slow, only when trying to shift hard...is this normal for evos?
Old Apr 17, 2013 | 12:06 AM
EvlEvoIXSE's Avatar
happened to me.... synchros are bad... sent it to shep had them rebuild it. well thats at least what happened to me :/
Old Apr 17, 2013 | 12:32 AM
God damnit...are these transmissions that lousy?
Old Apr 17, 2013 | 05:23 AM
Floseph's Avatar
Check out Jacks Transmissions as well they have info on everything powertrain related and do exceptional work as well.
http://www.jackstransmissions.com/pa...ros-for-evo8-9
http://www.jackstransmissions.com/pages/gear-damage
Old Apr 17, 2013 | 05:42 AM
blowngasket's Avatar
Not really, They are pretty well Built well the 5 speeds,
Some of the syncros just need a little work, and the preloads need to be tighter thats all.
Wanna see a bad trans Pay 50k+ for a M5 And replace it every 20k miles [SMG auto]
Old Apr 18, 2013 | 02:49 PM
socalx_dsm's Avatar
have you tried changing the fluid?
sometimes something this simple can make a difference
Old Apr 18, 2013 | 04:47 PM
Rawger's Avatar
Try changing the fluid and other advise first you never know, but ! It's most likely your syncro cuz it happen to me my third went out so I dropped alot of money into my 9 for new clutch flywheel and tranny.. If you gonna pull the tranny out might as well replace everything else wile your there.
Old Apr 18, 2013 | 04:49 PM
AWD Special's Avatar
Does anyone have any experience mixing GM Synchromesh in Evo transmissions? I know the Honda guys and Subie guys do it with great success. I would start by flushing the fluid first.
Old Apr 19, 2013 | 03:22 PM
Kada__85's Avatar
i guess im not the only one with a notchy trans:/ would switching to amsoil fluid help?
Old Apr 20, 2013 | 06:31 PM
Thore's Avatar
May help just changing your transmission fluid in general. Depends how long it's been since it was changed.
Old Apr 20, 2013 | 08:09 PM
Amsoil IMO is the best to use, it worked very well for me and I'm using it from now on
Old Apr 21, 2013 | 03:52 AM
slimjim1804's Avatar
These transmissions are notchy as hell by nature. I've driven quite a few over the years and they've all felt basically the same. Both Evos I've had were low mileage and still shifted like crap especially when cold. Shifter bushings will make an improvement.
I've tried Redline MT90 and Amsoil 75-90 and I'd give the nod to amsoil regarding shifting feel and improvement post-fluid change.
Posted from Evolutionm.net App for Android
Old Apr 22, 2013 | 03:35 PM
Kada__85's Avatar
what shifter bushings would you recommend?
shifting when cold is the thing i dread every morning. my transmission feels like crap
Old Apr 22, 2013 | 03:41 PM
Frew's Avatar
Sounds like its time for a rebuild, I have GM synchromesh in mine for the time being to help with shift feel, mine too is in need of a rebuild. With this light weight of an oil the only thing I would worry about is track use or long term wear protection, but as I have said I am not worried about wear protection, well aware it needs a rebuild and will be coming out this winter.
Old Apr 23, 2013 | 08:35 AM
DSMraver's Avatar
100k miles isn't bad for syncro service life on a car that's usually driven hard (Evo)... It shouldn't be too expensive if the trans still "works", and you'll have a stronger trans at the end of it all.
I'd send out your transfer case for inspection and LSD detailing if it hasn't been done, replacing the ring gear gets pricey, and a detail can save you buying a replacement LSD!
