Moving to Arizona
Old May 6, 2013 | 09:12 PM
e_kobz's Avatar
Originally Posted by EvoHead7
Thanks Jim in Tucan Ill be sure to take all of those things in to consideration once my car get out there.
E_kobz- My flight leaves this sunday the 12th and my car should be arriving that following friday, so ill deff be attending that Scottdale meet if everything goes as planned. and ill be living in Tempe, so thats like a hop jump and a skip... I just finished up registering to AZAWD, deff seems like a legit forum and last but not least, ive always wanted to do the E*85 mod, that might just have to be my first big purchase when i get out there!!
Thanks you both for the advise and welcoming with open hands, I look forward to meeting some of my EvoM family once i get settles out in good ol' Arizona!
Looking forward to it man
Old May 6, 2013 | 11:03 PM
e_kobz's Avatar
Do you know where in Tempe you'll be living?! I can help point out some E85 stations in your area. E85 is awesome but there's only a handful of stations that have it at the pump. Luckily you're in a good spot cause there's 3 different stations that have it in the Tempe/Scottsdale area
Old May 7, 2013 | 09:26 AM
A Furr's Avatar
I just moved from az to tx. I miss az so much, great state, phoenix is an amazing place to live.
Old May 7, 2013 | 09:31 AM
e_kobz's Avatar
+1
Old May 7, 2013 | 09:40 AM
blackoutVIII's Avatar
Hello my Evo Family, I have just excepted a job in Tempe, Arizona, but live in Pa now...So i was just wondering if there was anything i need to do to prepare my 06 evo 9 for this smoldering Arizona heat
I just moved to AZ in December, to Ft. Huachuca to be exact (been here before in the summer). You are going to love it, especially the views. But as far as the EVOs are concerned, get tuned for the fuel you will run, 91 Octane is crappy (probably isn't even a true 91) ES Tuned is good (in Tucson), vividracing is good to for installs, but no AWD Dyno, good layer of wax on the paint, ( frequently) I do mine once a month on EVO and Camaro, inbetween waxes I use the spay on wax as you dry type, for sure the tint, ensure you obtain the interior protectant that is UV rated, and for all purposes STAY ON TOP OF YOUR MAINTENANCE!!
My biggest complaint is the GAS!!! All the other items mentioned car cover (except on windy days), park in shade, etc are all good items and areas to focus on for maintaining your two EVOs.
P.S Once you tune for 91 gas, expect your WHP to drop if you were running 93 Octane. I dropped about 30 ponies from 93 to 91 at same PSI.
Old May 7, 2013 | 10:01 AM
e_kobz's Avatar
The the OP: stick with Phuong from Wingz Performance for all your building and tuning needs. you're in Tempe and he's in chandler, in your words only a hop and a skip away. I would only recommend Evan Smith from ES Tuned if you were down in Tucson or more southern AZ. Your tune will be inaccurate if you get it tuned down in Tucson and live here due to the drastic elevation changes. Wingz Performance will take good care of you man, check him out
Old May 7, 2013 | 11:05 AM
e_kobz's Avatar
Here is Wingz Performance's E85 Specials straight off their website:
Evo's 8/9 Stock turbo up to FPgreen turbo setup:
- Package 1: FIC 1050cc injectors + install + MAF or SD road tune (single E85 map) = $650 OTD
- Package 2: FIC 1050cc injectors + install + MAF or SD road tune (single E85 + 91 map) = $800 OTD (I recommend this setup)
Old May 7, 2013 | 02:57 PM
Jim in Tucson's Avatar
I just moved to AZ in December, to Ft. Huachuca...
I see two stations listed in Sierra Vista that sell E85. Your gas and power problems can both be easily solved.
Let me know if you ever visit Tucson.
Jim
Old May 8, 2013 | 01:25 PM
Jim
Will let you know man.
HBINK_7
Oct 9, 2015 04:15 PM
milruner
West Region
Aug 17, 2009 11:40 PM
crapsstickman
Apr 15, 2005 04:51 PM
Static
West Region
Mar 13, 2004 08:16 AM
