HELP! i just broke the heater control knob
Old Nov 22, 2016 | 01:00 PM
TJs98GT's Avatar
Originally Posted by SilverShadow03
You DO NOT need an entire new HVAC unit.
Unless they're currently out of stock, you need the shaft that broke off. You can get one off ebay like I did. Cost me $22.50 shipped.
1 Heater Control Knob - $10 & change (stealership) part number at home, I'll update the part number later. You might not need this if the prongs on the back are still in good shape. Mine broke along with the shaft.
1 MR979515 WIRE $5.44
1 7801A110 HEATER CONTR $16.00 (revised gears)
These last two I purchased from MitsubishiParts.net....charged me $10.95 shipping! Oh well...Russell couldn't do anything about it.
Replacement of the actual broken shaft is a bit tricky. It pops out but there are gears behind it and they have to be remain in the same position or marked accordingly so they go back together exactly the same way. That way you have full temperature range with the new knob. I found out the hard way and went through a trial and error session...and a six pack before getting it just right LOL
I posted this video in the above Mega HVAC thread showing you how to replace the parts I posted above excluding the actual shaft replacement:
How To Video
Hope this helps you out.
Going as far as telling someone they DO NOT NEED the box is replaced is a stretch and assumption without being there to diagnose each individual cars needs. There is a really good chance the repair above will work for most people, but ultimately it is not the end all of repairs for every car. These cars do have issues with the heater boxes themselves.
The 05 Evo MR I just picked up is a perfect example. It already has all the updated and revised parts but still has the issue. If you disconnect the cables and try to manually turn the levers on the box by hand its really difficult but can be done, there is no way a small cable is going to provide that much force through the knob.
Unfortunately it looks like I will end up having to replace that whole unit behind the dash unless there is a repair method for whatever is binding up inside.
Old Nov 22, 2016 | 01:34 PM
Pal215's Avatar
It's not as bad as they say, just take your time and make a deal with an AC shop to flush your system before you begin your work and then fill it when the work is done. Once you have the dash out and then mix box, you will have to break some tabs off to get inside the mix box. The kit comes with screws that replace those tabs afterwards. The entire sliding door gets replaced since the gears are attached to it.
-pal215
Old Nov 22, 2016 | 08:01 PM
barneyb's Avatar
I sat my favorite beverage on the dash. It toppled when I moved the car. Now my AC switch works about once in twenty tries. HVAC - always something.
Old Nov 22, 2016 | 09:18 PM
Pal215's Avatar
Blue Moon, Guinness, Red Trolley ? I'd do the same.
HVAC - Has Very Annoying Components
-pal215
Old Nov 23, 2016 | 09:41 PM
ReidFletcher's Avatar
There's a store on EBay that sells the replacement knob shaft. Much stronger type of plastic. And do yourself a favor and buy the revised gear set w/cable. Mine is butter smooth now.
https://www.ebay.com/itm/331942001114
riceball777
Jan 7, 2018 05:23 PM
riceball777
Dec 25, 2016 07:49 PM
riceball777
Nov 8, 2016 02:23 AM
riceball777
Oct 26, 2016 06:26 AM
riceball777
17
Jun 3, 2016 08:41 AM
