so why does CA get 91 gas
Old Feb 19, 2004 | 12:17 AM
Az3ar's Avatar
Just moved to OC and started using 91 on my EVO, tell you the truth i did not notice a big deal i am sure i lost couple hrs but nothing major. anyways, i was searching the net why did this happen why do we get capy gas here, and thats what i came up with. check this out and read carefuly
http://www.sportcompactcarweb.com/ed...201scc_techno/
it had all the answers why did CA moved from 92 to 91 and why we dont get 93 and whats the difference as well.
Old Feb 19, 2004 | 12:35 AM
TeamNeXusOz's Avatar
so does octane booster actually work?
Old Feb 19, 2004 | 12:51 AM
Az3ar's Avatar
yup it does, u just have to choose the right kind
Old Feb 19, 2004 | 01:00 AM
and that would be?
Old Feb 19, 2004 | 01:04 AM
Az3ar's Avatar
I use nos brand every once a while, big brand name???
Old Feb 19, 2004 | 01:07 AM
ic...
Old Feb 19, 2004 | 07:11 AM
mprtklr's Avatar
octane boosters only boost it a percentage of a point. like 1 bottle will go from 91 to 91.1 and so forth.
Old Feb 19, 2004 | 07:27 AM
umiami80's Avatar
Go to your Local Hardware store, get Some Xyleen, it'll boost it up nicely, just make sre you add an OZ of Marvals Mystery oil as you need lubricant in the mix.
That stuff has 117 Octane rating, you mix 2 gallons of that into 10 of 91 gas, you'll get like 95 octane
Old Feb 19, 2004 | 09:43 AM
Obsoleteasian's Avatar
that was fun to read.
Old Feb 19, 2004 | 10:26 AM
Az3ar's Avatar
nope octane boosters do raise you boost atleat 1 full pint depanding on kind.infact i got one that raise it one4 points
Old Feb 19, 2004 | 10:34 AM
zlancer's Avatar
using octaine boosters will destroy your oxygen sensors (i think the cat too) and make your spark plugs turn rustic in color...and will go bad eventually. you can use them on ****ty cars but don't put them in your evo motor. just get some unleaded race gas.
Old Feb 19, 2004 | 10:37 AM
CarPhoto.net's Avatar
Read the labels.
10 octane points equals 1 octane number.
If the nosz brand adds 7 points its really changing your gas to 91.7
http://www.CarPhoto.net
Old Feb 19, 2004 | 10:38 AM
Az3ar's Avatar
i dont use them to much anyways just on the way here
Old Feb 19, 2004 | 11:06 AM
eclipsegs2k1's Avatar
this is just a question relating to octane. anyway, in Japan, is it true that they can get 100 octane at the pump at most or all of their gas stations?
Old Feb 19, 2004 | 11:15 AM
Want to Evo's Avatar
They get 100 octane ron which is a different measure than the united states. It is really much lower in our terms of octane.
