Can Someone post a Pic? Fuse Panel
I'm looking for the correct fuses (I just bought an evo 9 SE) and I want to verify if I'm missing some or incorrect amperage on others.
* My Dash lights aren't working but I would like to make sure all are correct BUT the dash fuse is ok
Thanks in Advance.....For an Evo 9 under the steering wheel as well as in the engine for others to see as well but I really only need it under/next the steering wheel
Dash fuse box diagram
https://www.evolutionm.net/forums/ev...use-panel.html
I did check that side panel
For some reason I had a 10 amp in the 10 spot and one in the 16 which is for a rear fog light
I found this one on ebay BUT it must be a euro because it also has a 10 amp in
16 spot which is the rear fog light....I just wanted to see what others had to make sure....Any pics for an 06 would be great
EvokidIX
Mar 12, 2016 04:08 PM
shiftdsm E
Aug 4, 2005 11:29 PM
