evo 8 wants to stall
Old May 21, 2013 | 07:38 PM
hoytbow09's Avatar
Hey everyone I have a question my EVO wants to stall out when I rev up the engine..It also does it when I'm driving an if I push the clutch in over 2000 rpm it wants to stall also. Does anyone no what could be causing this....thanks!!!
Old May 22, 2013 | 05:34 AM
donzilla2004's Avatar
You almost need to have someone watch it on a scanner to see if your crank sensor is dropping out. However it could be many things causing this. A big vacuum leak can cause similar situations to. Start with all the basics.
Old May 22, 2013 | 06:42 AM
chu's Avatar
chu
^Start with basics as suggested. CHeck for vacuum and boost leaks. Check MAF sensor for damage and plug connection. Are you on MAF and venting bov to atmosphere? Also check idle control valve.
Old May 23, 2013 | 02:08 PM
hoytbow09's Avatar
Ok thanks for the help. It looks like I have a few sensors to check lol...but I do have the bov in atmosphere!!!
Old May 23, 2013 | 05:39 PM
If you are running the factory maf, then you need to recirculate the bov, running it to atmosphere can cause these issues.
Old May 23, 2013 | 06:21 PM
PureDrivePerformance's Avatar
What are your mods? What type of BOV?
If your BOV can't recirculate you could always go Speed Density.
Old May 24, 2013 | 09:27 AM
hoytbow09's Avatar
yeah i have the stock MAF i will recirculate the BOV to see if that does it... i have the HKS BOV and the mods are headers, 3in.down pipe, 3in. test pipe, 3 in. catback, even the o2 housing, intake, BOV,upper an lower intercooler piping, intercooler,mini battery kit.
Old May 25, 2013 | 12:50 AM
Evo5madness's Avatar
My evo 5, now has 8 motor was stalling, mainly as revs dropped off. We found problem was BOV was sticking open. Relaced BOV and problem gone
Old May 26, 2013 | 05:37 PM
hoytbow09's Avatar
Yeah I think it might be the bov I just recirculated it an it seemed to be fine until the car warmed up an then it started doing it. It seemed like the bov wasn't closing cuz I couldn't really hear it go off ??
rich3389
Sep 8, 2024 07:27 AM
gixxer1k
Oct 17, 2018 09:23 PM
khay silk
Dec 5, 2015 11:21 PM
khay silk
Oct 8, 2015 05:00 PM
BOOSTEZ
14
Jan 11, 2006 02:21 PM
