Help with iac!
Old May 30, 2013 | 08:29 PM
raven1231's Avatar
Help with iac!
Hey I have been having issues with the car starting and then instantly dying. I have been trying to solve the problem for weeks. I pulled the IAC today to test it. It was completely black. I plugged it into the connector and had my girlfriend turn the car to the on position. I hear ticking but the plunger didnt move. Does this mean its bad?
Old May 30, 2013 | 10:05 PM
MrJuls's Avatar
From what I've read on here it is supposed to move.If it's not it's dead.I've had the same problem and bought a new one.
Old May 31, 2013 | 07:52 AM
Tekniq's Avatar
https://www.evolutionm.net/forums/5708673-post5.html
The part number is 1450A069.
The part is interchangeable with the following:
CHRYSLER SEBRING 2.4L 4 Cyl SOHC 16V, 4-Speed Automatic 2004
CHRYSLER SEBRING 2.4L 4 Cyl SOHC 16V, 4-Speed Automatic Coupe 2005
CHRYSLER SEBRING 2.4L 4 Cyl SOHC 16V, 4-Speed Automatic LX 2001, 2002, 2003
CHRYSLER SEBRING 2.4L 4 Cyl SOHC 16V, 5-Speed Manual 2004
CHRYSLER SEBRING 2.4L 4 Cyl SOHC 16V, 5-Speed Manual LX 2003
DODGE STRATUS 2.4L 4 Cyl SOHC 16V, 4-Speed Automatic SE 2001, 2002, 2003
DODGE STRATUS 2.4L 4 Cyl SOHC 16V, 4-Speed Automatic SXT 2004
DODGE STRATUS 2.4L 4 Cyl SOHC 16V, 4-Speed Automatic SXT Coupe 2005
DODGE STRATUS 2.4L 4 Cyl SOHC 16V, 5-Speed Manual SE 2001, 2002, 2003
DODGE STRATUS 2.4L 4 Cyl SOHC 16V, 5-Speed Manual SXT 2004
DODGE STRATUS 2.4L 4 Cyl SOHC 16V, 5-Speed Manual SXT Coupe 2005
Old Jun 6, 2013 | 07:28 PM
raven1231's Avatar
Well IAC didn't fix the problem. Does anyone else have any idea what the hell could be wrong with my car. I am getting so frustrated and no one seems to know what it could be. It just starts idles for a few seconds then dies instantly. If I rev the engine when starting it then it will keep run and idle like normal.
Old Jun 6, 2013 | 08:02 PM
barneyb's Avatar
Maybe do a boost leak test.
Old Jun 6, 2013 | 08:11 PM
raven1231's Avatar
yeah but once I give it gas it continues to run fine. Wouldn't a boost leak be constant.
Old Jun 6, 2013 | 09:10 PM
xXevo8RavenXx's Avatar
could maybe be a "spark" problem?
Old Jun 6, 2013 | 09:36 PM
heavens turbo's Avatar
mods/ ses lights? more info needed, there could be a lot of problems ranging from egr, coolant temp sensor, timing off, ect.
Old Jun 7, 2013 | 01:56 AM
MrJuls's Avatar
Do a diagnostic check.Is the engine light on? Check for error codes.
Maybe cam sensor...?
Old Jun 7, 2013 | 04:25 AM
raven1231's Avatar
Replaced spark plugs, EGR solenoid and IAC. As far as mods the car is stock except for a HKS turbo back exhaust, BLOX filter, AEM wideband 02, aftermarket boost gauge, aftermarket clutch and flywheel. Nothing that should cause it to run like it is now. There are also no visible vacuum leaks either.
Also there is no check engine light or any other light for that matter.
Old Jun 7, 2013 | 04:38 AM
MrJuls's Avatar
Have you done a boost leak test?
Old Jun 7, 2013 | 05:09 AM
Tekniq's Avatar
LOL @ no visible vacum leaks. Do a boost leak test.
Old Jun 7, 2013 | 05:22 AM
raven1231's Avatar
I would but I don't have an air compressor.
What I meant by no visible vacuum leaks, is that I checked the lines and they are all connected.
Old Jun 7, 2013 | 10:32 AM
Tekniq's Avatar
You could have a leak at your fuel injectors or your throttle body seals.
Old Jun 7, 2013 | 10:52 AM
raven1231's Avatar
anyway to check without a compressor? I heard I spray bottle with soapy water?
