Opinions on track/street turbo
FP Black is a 600hp turbo. If you want more power down the road then it's the ideal turbo for you. I would personally go FP Red since it's almost stock like spool. An excellent turbo for circuit!
If you're looking for big pumpgas power, then an o2 dump is a big plus, as it frees up lots of backpressure. I would definately run a ported or even tubular exhaust manifold, and port the stock IM and TB while you're at it. A big intercooler(shoot for 4", settle for 3.5 if need be) willl help loads as well. It's all about flow and heat management on **** gas(Ie, pumpgas).
For a road course all those turbos you listed will lag so hard you'll think the engine shrunk down to half its size. Unless you literally line the car up on the straight before hitting the throttle you will feel the lag bad in midcorner part-throttle. Transient response especially at part throttle is very hard to see just by looking at dyno graphs.
And if you have ACD there won't be enough torque midcorner to convince it to do its magic and then you get dreaded understeer.
Bottom line don't go larger than fpred. It can do 600whp if you get people like Curt Brown to look at your car.
I like my garrett gtx 3071r over the red. DBB and similar spool as well as being stock location as well. Made over 500 whp for me on e85 but since I have 116k miles on the clock, I toned it down a bit. It is also cheaper moneywise, but still a very solid turbo. Solid spool around 3100 rpm.
i would listen to the guys giving you advice or dont ask.
all of the turbos you listed are solid options. the thing is, they all are good at something and worse at others. sure, the black, 6266 etc turbos will satisfy your thirst for power down the line, but if you strap on a black, and then go to say summit, or even VIR, your not going to use the power at all save for the straight (maybe).
imo, i would do every supporting mod necessary now, then all you have to do is sell turbo, buy turbo, re-tune. but you need to decide if the extra power is worth the drop in track performance (which is your decision and may very well be).
one thing you didnt mention, which I am assuming/hoping you have is springs retainers seats for your s2s. if you dont, get them asap otherwise you wont realize the true potential of any of the turbos listed.
gl with the set up, post numbers when done
A 6266 on a 2.0L will be laggy for circuit. I would personally go with a FP Red with a ported exhaust manifold and an O2 Dump. If you want to grow later, then a full turbo kit with a gt3037. This will allow you to grow and put a different turbo when that 3037 starts feeling a bit slow
For starters, you might want to do some searching as this question has been asked ad nauseum. Additionally the Motorsports forum will have a lot more valuable information if your intent is to build a car for road racing.
That being said, all of the turbos you are talking about are far too large for a road race car. Some of the fastest guys around drive Evo's with well under 400 whp. Big power numbers are meaningless for speed around a track unless they are backed up with substantial improvements in every other area of the chassis and a driver who can use them.
If you plan to do track days and learn how to drive fast, I recommend staying with the stock turbo. I don't know what your racing experience is, but judging by the question I'm assuming you are just starting out. The stock turbo is more than enough when you are learning to take the car to it's limit. Starting out with tons of power will actually hurt your learning curve.
If you plan to compete (wheel to wheel or TT) your turbo selection is going to depend on your intended class. I'm running a 58 lb/min BBK-3B capable of well over 500 whp, but I'm class limited to ~420 whp for TT2. The more power you run the more you compete against other people running ludicrously modified cars with heavy weight reduction, full aero, and finely tuned suspensions.
A turbo like an FP Black or 6266 is going to be virtually worthless on a 2.0L motor on a road course. You would probably be faster with a properly set up stock turbo car.
