Stronger "Regular" Size Battery
Old Jun 16, 2013 | 02:47 PM
kyoo's Avatar
Do you guys have any suggestions for a much stronger than stock battery? I've only been driving my evo ~once per month, and due to having a security system hooked up I need to jump start the battery every time I start the car. I haven't driven my car since I've needed to pull my rear diff (5/19) but I tried to start it the other day to get the fluids going a little, and of course it's dead...
Suggestions? Any stock-sized replacements with incredible life? I have to imagine there's something, given all the small batteries with decent life out there
Old Jun 16, 2013 | 06:33 PM
NorCal Lancer's Avatar
optima red top battery?
Old Jun 16, 2013 | 06:38 PM
SilverShadow03's Avatar
Hook it up to a battery trickle charger/battery tender while garaged to avoid having to jump it once a month. Dont waste your $$ on a battery when you dont have to.
It'll start every time.
Old Jun 16, 2013 | 06:42 PM
I've used this before with good results.
http://www.amazon.com/gp/aw/d/B00068...=5336121857-20
Old Jun 16, 2013 | 06:45 PM
Or disconnect battery if safely garaged at home.
Old Jun 16, 2013 | 06:50 PM
killerpenguin21's Avatar
yup battery tender. i got the junior for cheap at autozone. it takes a long time if the car is dead as it is less amps than the full up tender, but if its semi juiced and you plug it in an hour before you wanna drive, or just leave it on all the time it works like a charm.
Old Jun 16, 2013 | 08:44 PM
heavens turbo's Avatar
I got the diehard platinum agm battery. it is the same as an oddessy agm. it was 200 bucks, but was completely worth it. the stock battery lasted 8 years, but was starting to slow start in the cold. I did a lot of research before getting this battery. stock size and fits like a champ. I have heard good and bad about optima, but they may still be ok.
Old Jun 17, 2013 | 12:35 AM
hatesposers's Avatar
There is a solar powered battery maintainer that you can buy at harbor freight. Ive used it with great success on work trucks that rarely get driven. Plugs into the cigarette lighter and goes up in the windshield.
I would suggest this over swapping batteries
Heres a link:
http://www.harborfreight.com/15-watt...ger-68692.html
Old Jun 17, 2013 | 03:17 AM
AdrenalineRush's Avatar
Agreed. My car has set for weeks at a time and more than a month when I was in Africa. Car starts up every time without issue. The battery had outlasted my new starter that was put in about 2 years ago lol
Old Jun 17, 2013 | 07:26 AM
kyoo's Avatar
thanks for the input - sounds like optima redtop may be the best traditional option -
i do have a trickle charger, but i live in an apt right now, no outlet closeby
Old Jun 17, 2013 | 07:41 AM
tiggeryellow1's Avatar
Veteran: Army
IF it's trully a battery issue and your altenator isn't on the way out Optima Red Top FTW!
Old Oct 17, 2013 | 09:16 AM
kyoo's Avatar
mega bump for this - thanks for the tips. Optima Red Top it is, when the time comes. Wish small batteries could pack the power full size batteries can
(capacity, not reserve)
Old Oct 18, 2013 | 07:20 AM
steven121's Avatar
on the speed channel they came out with a new type of battery not necessarily stronger but made of I think it was made out of aluminum versus lead, the battery is extremely light, and the conductivity is extremely reliable,longer lasting, and almost corrosive resistant
Old Oct 18, 2013 | 02:37 PM
boostedwrx's Avatar
I was always a fan of the Costco or Sears Diehard Platinum.
Old Oct 18, 2013 | 07:42 PM
Abacus's Avatar
If your battery has been dead before when you charge it , it will only be 85% of what it used to be. So, if you it died a few times its toast.
If you get an optima, it needs a special charger to support an AGM battery.
http://www.optimabatteries.com/us/en/support/faqs/ Charging
