Need Help?
Old Jun 17, 2013 | 03:20 PM
manthny18's Avatar
Need Help?
I need help with where to put the oil line fitting on oil housing there are 2spots where i can put it just need to know which 1. Its a 03 evo 8 andgonna run a persicon 6266 journal bearing lmk guys need help thank you.
Old Jun 18, 2013 | 05:27 AM
donzilla2004's Avatar
Why aren't you running the oil line to the head where it should be?
Old Jun 18, 2013 | 05:33 AM
evo8426's Avatar
The head doesn't provide enough pressure and volume of oil for a JB turbo.
You want to install the oil line in the plug location closest to the right front wheel.
Old Jun 18, 2013 | 05:37 AM
There should be 3 3/8" plugs on your oil filter housing, two of them go to the cooler, you should be able to pull the 3rd plug and run a feed off of that if I'm not mistaken.
Old Jun 18, 2013 | 10:58 AM
manthny18's Avatar
ok thanks guys. i will use the one closest to the wheel.
Jsiebert
Feb 15, 2014 10:24 AM
evoboy2006
Feb 11, 2013 10:12 AM
degin219
May 31, 2011 03:23 AM
Xcited
17
Nov 29, 2009 10:38 AM
Knightr
Aug 13, 2009 12:19 PM
