apexi power fc edu
Old Jun 29, 2013 | 04:14 PM
EvolutionRR's Avatar
apexi power fc edu
question about the apexi power fc ecu. is this worth buying? Is this better than stock ecu?is this plug and play?Does this need a tune right away when installed? i know they run about 1000 dollars brand new. just wondering?
Old Jun 30, 2013 | 08:36 PM
okevolutionVIII's Avatar
They work fine and would need at least a rough tune. The only flaw I can tell is that it doesn't retard timing/ richen AFRs/drop boost/ switch maps if knock occurs.
Old Jun 30, 2013 | 09:23 PM
SmurfZilla's Avatar
Originally Posted by EvolutionRR
question about the apexi power fc ecu. is this worth buying?Is this better than stock ecu?is this plug and play?Does this need a tune right away when installed? i know they run about 1000 dollars brand new. just wondering?
the commander is about the only thing it has over the stock ecu.....otherwise, waste comparatively.
94AWDcoupe
Jan 4, 2017 09:05 PM
OPENA(671)
Dec 31, 2013 01:15 AM
EvoVan
Sep 30, 2012 03:31 PM
johnnyli
14
Jun 29, 2009 12:52 PM
doktorevo
May 1, 2005 09:33 PM
