AEM Wideband staying at 14.7/8
Old Jul 1, 2013 | 06:48 PM
4G63_EVO's Avatar
So I wired up my AEM without the sensor plugged in and it read 14.7 (I know it shouldnt be reading anything) My problem now is that I finally plugged the sensor in and its reading exactly the same, nothing has changed. What could the problem be?
Old Jul 1, 2013 | 07:01 PM
egis's Avatar
Ok,when you turn the ignition on(don't start the car) it should self calibrate and show numbers 111,222,333........999,then REn,UO6,POO,14.8. Do you see all that?if not check the wiring.good luck bro.
Old Jul 1, 2013 | 07:29 PM
4G63_EVO's Avatar
it goes straight to 14.7 =[
Old Jul 1, 2013 | 07:34 PM
Teal2nnr's Avatar
How did you wire it?? or was this installed by someone else.
Old Jul 1, 2013 | 07:41 PM
4G63_EVO's Avatar
I installed it, Red wire to a fuse powered by ignition, black to ground, and the sensor wire going straight to the 02
Old Jul 2, 2013 | 05:12 AM
pls1968's Avatar
Was it brand new when you installed it? That happened to me recently and it turns out the sensor was bad. Got one brand new on Ebay for under $50 and it fixed the problem.
Old Jul 2, 2013 | 05:58 AM
egis's Avatar
But did you get the whole kit from AEM(o2 sensor included) or you bought just a gauge from somebody else,and sensor separately?you know maybe sensor is shot or simply different sensor that ain't working together.
Old Jul 2, 2013 | 08:26 AM
4G63_EVO's Avatar
Brand new when I bought it, from extremepsi.con and the whole kit
Old Jul 2, 2013 | 09:47 AM
TheBoz's Avatar
Make sure you locked the sensor all the way into the plug. After that do this:
crappy video, but more or less you get a rag and you spray it with parts cleaner, and you put the sensor in the middle. Your gauge should go full rich. if it does not you have a bad sensor.
Old Jul 2, 2013 | 11:43 AM
4G63_EVO's Avatar
Check it out
Old Jul 2, 2013 | 03:42 PM
slimjim1804's Avatar
had this happen in the past when my wideband sensor wiring was chewed up from a hack job P.O
Posted from Evolutionm.net App for Android
Old Jul 2, 2013 | 03:50 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
That's... strange.
Maybe a faulty gauge? It happens.
Have you tried contacting AEM?
Old Jul 2, 2013 | 04:13 PM
4G63_EVO's Avatar
Originally Posted by golgo13
That's... strange.
I did, just waiting on their reply, I did notice when I plugged the sensor wire into the back of the gauge I had trouble getting it in... Dont know maybe it is a faulty gauge 0.o
Old Jul 2, 2013 | 07:54 PM
xXevo8RavenXx's Avatar
...try to call aem.. they never reply to email
Old Jul 2, 2013 | 08:20 PM
4G63_EVO's Avatar
Could I need to do something with the calibration screw?
