heat soak or another issue
Old Jul 10, 2013 | 10:02 PM
impact blue's Avatar
Gee guys its really hot as heck out there this summer. I notice my car does pull as hard as it used to you know. I got my setup with gsc stage 2cams, intake, exhaust, downpipe with a tune and stock intercooler.
Now with this setup I know I gotta be pushing more psi than just 15 in third gear could I be suffering from heat soak. Is the psi levels normal for this setup without a boost controller?
Old Jul 11, 2013 | 02:50 PM
ProPilot04's Avatar
Your car should certainly be pushing more than 15 psi.
But... 2 things.
1. Warmer air is less dense, and that will certainly slow the car down.
2. If you're boosting low, it could be a boost leak as well. I'd start with doing a boost leak check, and go from there.
Old Jul 11, 2013 | 03:54 PM
Can you tell me which psi I should be at in each gear?
Old Jul 13, 2013 | 09:32 AM
Found the issue it was a boost leak at the throttle body . did my search heard its common with the IX's is this true?
Keith6110
May 16, 2014 05:46 AM
Noe18
Aug 13, 2013 09:41 AM
hachansoo0413
Oct 12, 2012 04:01 PM
widge
May 26, 2011 11:36 PM
fyreant
Aug 11, 2007 11:28 PM
